1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: FrameGrabber For VME/PMC VxWorks/EPICS use
To: "Leonard J. Reder" <[email protected]>
Date: Fri, 01 Oct 1999 09:27:47 -1000
"Leonard J. Reder" wrote:
> Hello all,
> I am interested if anyone in the EPICS community is utilizing a
> current technology frame grabber board with EPICS/VxWorks.  The
> board must be either PMC, that is a PCI doughter card which
> plugs into, in our case, the VME Motorola MVME2307 PPC SBC.  Or
> it can also be a stand alone frame grabber which connects
> directly to a VME bus.
We are using Data Translation DT1451 boards.  They are VME boards
with very little on-board processing.  They can do things like
add images.  I have ported the DT-IRIS package to run under vxWorks,
and it provides about everything the original did.  We don't use a
direct EPICS interface, but that should be easy enough to do.  These
modules are no longer in the catalog, but DTI would probably make
you one.  They are at http://www.datatranslation.com.
Good luck!
William L. Cruise                             [email protected]
Electronics System Supervisor                   FAX:    808 885-7288
Canada-France-Hawaii Telescope                  Voice:  808 885-3122
P.O. Box 1597                     http://www.cfht.hawaii.edu/~cruise
Kamuela, HI   96743
FrameGrabber For VME/PMC VxWorks/EPICS use Leonard J. Reder
Prev: FrameGrabber For VME/PMC VxWorks/EPICS use Leonard J. Reder
Next: Re: FrameGrabber For VME/PMC VxWorks/EPICS use Detlef
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
