1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: bug in EPICS R3.13 and R3.12---booting vme162
To: [email protected], [email protected]
Cc: [email protected]
Date: Mon, 26 Jul 1999 08:58:54 -1000
...may not be related, but there is a problem with tcsh and some ftp servers;
the ftp server checks the shell and if it's not in a list of known ones it
rejects the incoming call; here's an excerpt from an (admittedly old) tcsh
FAQ:
5.  I just made tcsh my login shell, and I cannot ftp any more?
    Newer versions of the ftp daemon check for the validity of the
    user's shell before they allow logins. The list of valid login
    shells is either hardcoded or it is usually in a file called
    /etc/shells. If it is hard-coded, then you are out of luck and
    your best bet is to get a newer version of ftpd. Otherwise add
    tcsh to the list of shells. [For AIX this file is called
    /etc/security/login.cfg]. Remember that the full path is required.
    If there is no /etc/shells, and you are creating one, remember to
    add /bin/csh, /bin/sh, and any other valid shells for your system,
    so that other people can ftp too :-)
William
Prev: Re: GreenSpring IP-DAC driver? Graham Waters
Next: Re: bug in EPICS R3.13 and R3.12---booting vme162 Andrew Johnson
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: bug in EPICS R3.13 and R3.12---booting vme162 Susanna Jacobson
Next: mbbiDirect record Leonard J. Reder
