1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Xycom 566 waveforms
To: [email protected]
Date: Thu, 12 Feb 1998 07:01:27 -0700 (MST)
The xycom 566 waveform driver support sets up the 566 to take only the
first channel as a high speed digitizer. If you set up the card as a
digitizer, the A/D RAM (the list of channels to convert) will only have
the first channel in it. To use an array record to read all 32 channels
you will either need to:
write new device support for the array record to read the 32 registers
into the array when it is strapped as a 32 channel s/e card -
or write new device and driver support to use a different base address
and then program the card to your needs.
If the card is converting fast enough - I think the first is a better
solution.
Re: Xycom 566 waveforms Andrew Johnson
Prev: CapFast Viewer - a "viewing only" version of CapFast Dr. Chong Lee
Next: Re: gdct313 - stepper-motor record problem. Bob Dalesio
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Xycom 566 waveforms Andrew Johnson
Next: Re: Xycom 566 waveforms Ned Arnold
