> Garrett D. Rinehart wrote:
> > I'm trying to read all 32 channels of a Xycom 566 into a
> > waveform record, but I cannot get it to work.
> > I have tested the board with AI records and it works fine.
> > When I remove the AI's and put in a WF, it just looks at me
> > stupidly.
Andrew wrote:
> If you look at the drvXy566.c file you'll see that ai and wf support
> effectively use two separate drivers, and I think they use different
> base addresses for their cards.
Andrew is correct. My "very old notes" indicate the following ...
Xycomm 566 Mode Register Address (A16) Memory Address (A24)
Single Ended 0x6000 0x000000
Differential 0x7000 0x040000
Differential Latched 0xE000 0x0C0000
Waveform Mode 0x9000 0x080000
These values, of course, can be modified using module_types.c
Ned
gdct313 - stepper-motor record problem. Bill Brown
stepper-motor vs. motor record Janet Tvedt
<1998>
Re: Xycom 566 waveforms Bob Dalesio
<1998>
