1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Xycom 566 waveforms
To: "Garrett D. Rinehart" <[email protected]>
Cc: [email protected]
Date: Wed, 11 Feb 1998 18:11:08 +0000
Garrett D. Rinehart wrote:
> I'm trying to read all 32 channels of a Xycom 566 into a
> waveform record, but I cannot get it to work.
> I have tested the board with AI records and it works fine.
> When I remove the AI's and put in a WF, it just looks at me
> stupidly.
If you look at the drvXy566.c file you'll see that ai and wf support
effectively use two separate drivers, and I think they use different
base addresses for their cards.
> When I execute "ai_xy566_io_report 1", I get a nice listing
> of all 32 channels and they do change (consistently) with
> the input voltage I apply. However, when I display memory
> starting at the BPTR address, I see 64 bytes (I specified
> longs in the WF record) of nice empty space that never
> changes.
Try executing "xy566_io_report 1" instead, and you may see something
different (like no cards present maybe).  I've never tried to use wf
records with the 566, so that's about all I can contribute, but it
should get you started.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Re: Xycom 566 waveforms Bob Dalesio
Xycom 566 waveforms Garrett D. Rinehart
Prev: Xycom 566 waveforms Garrett D. Rinehart
Next: gdct313 - stepper-motor record problem. Bill Brown
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Xycom 566 waveforms Bob Dalesio
