1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Bug in DM using long records?
Date: Fri, 6 Jan 95 14:03:20 MST
My humblest apologies for dm difficulties reported by Andrew
(and acknowledged by others.)  Edd/dm were actually in use
before the EPICS long records were created.  I fixed dm long
ago to support the long types, but the fix was done in a version
that has not been officially released with EPICS.  I neglected to
put the fix into the release, hence the apology.  I can outline
the simple fix needed so that people can rebuild dm at their sites
or I can build a statically linked copy for SUNs with the fix here.
Those using the 2.0 beta release should not experience the problem.
The work-around Carl Timmer outlined is a good one, if you'd rather
just wait for the next release.  If anyone wishes to have fixes
before taking a new release, please indicate so.
Thanks!
Deb
Prev: EPICS env parameters Jeff Hill
Next: Re: EPICS env parameters winans
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Bug in DM using long records? Tim Mooney
Next: Release 3.12 Memory usage Marty Kraimer
