Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Build failed in Jenkins: epics-base-3.16-linux32-test #78
To: core-talk@aps.anl.gov
Date: Tue, 23 May 2017 23:49:11 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/78/display/redirect>
[...truncated 34.22 KB...]
	    T_A=linux-x86 test-results
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/template/base/O.linux-x86'>
make[3]: Nothing to be done for `test-results'.
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/template/base/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/template/base'>
make -C template/ext test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/template/ext'>
make -C O.linux-x86 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/template/ext/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/template/ext/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/template/ext'>
make -C ./libCom test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom'>
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom'>
make -C libCom/RTEMS test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/RTEMS'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/RTEMS/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/RTEMS/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/RTEMS'>
make -C libCom/test test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/test'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/test/O.linux-x86'>
prove --failures --ext .tap --exec cat --color epicsUnitTestTest.tap epicsTypesTest.tap epicsInlineTest.tap epicsCalcTest.tap epicsAlgorithmTest.tap epicsMathTest.tap epicsMMIOTest.tap epicsEllTest.tap epicsEnvTest.tap epicsErrlogTest.tap epicsStdioTest.tap epicsStdlibTest.tap epicsSockResolveTest.tap epicsStringTest.tap epicsTimeTest.tap epicsTimeZoneTest.tap epicsThreadTest.tap epicsThreadOnceTest.tap epicsThreadPriorityTest.tap epicsThreadPrivateTest.tap epicsThreadHooksTest.tap epicsThreadPoolTest.tap epicsExitTest.tap epicsTimerTest.tap ringPointerTest.tap ringBytesTest.tap epicsEventTest.tap epicsMutexTest.tap epicsSpinTest.tap epicsAtomicTest.tap macDefExpandTest.tap cvtFastTest.tap macLibTest.tap taskwdTest.tap blockingSockTest.tap epicsMessageQueueTest.tap epicsStackTraceTest.tap ipAddrToAsciiTest.tap
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
All tests successful.
Files=38, Tests=3964,  1 wallclock secs ( 0.91 usr  0.13 sys +  0.03 cusr  0.08 csys =  1.15 CPU)
Result: PASS
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/test/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/libCom/test'>
make -C ca/client test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client'>
make -C ca/client/tools test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/tools'>
make -C O.linux-x86 -f ../Makefile TOP=../../../../.. \
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/tools/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/tools/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/tools'>
make -C ca/legacy/gdd test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/gdd'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/gdd/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/gdd/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/gdd'>
make -C ca/legacy/pcas test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas'>
make -C ./build test-results
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/build'>
make -C O.linux-x86 -f ../Makefile TOP=../../../../../.. \
make[4]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/build/O.linux-x86'>
make[4]: Nothing to be done for `test-results'.
make[4]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/build/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/build'>
make -C ./example test-results
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/example'>
make -C ./directoryService test-results
make[4]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/example/directoryService'>
make -C O.linux-x86 -f ../Makefile TOP=../../../../../../.. \
make[5]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/example/directoryService/O.linux-x86'>
make[5]: Nothing to be done for `test-results'.
make[5]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/example/directoryService/O.linux-x86'>
make[4]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/example/directoryService'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/example'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas'>
make -C ./ioc test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc'>
make -C ca/legacy/pcas/ex test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/ex'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/ex/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/ex/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/legacy/pcas/ex'>
make -C ca/client/perl test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/perl'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/perl/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/perl/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ca/client/perl'>
make -C ioc/db/test test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/db/test'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/db/test/O.linux-x86'>
prove --failures --ext .tap --exec cat --color dbScanTest.tap dbShutdownTest.tap dbPutLinkTest.tap dbLockTest.tap dbStressTest.tap testdbConvert.tap callbackTest.tap callbackParallelTest.tap dbStateTest.tap dbCaStatsTest.tap dbCaLinkTest.tap scanIoTest.tap dbChannelTest.tap dbChArrTest.tap chfPluginTest.tap arrShorthandTest.tap recGblCheckDeadbandTest.tap testPutGetTest.tap dbStaticTest.tap
dbScanTest.tap ............... ok
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
dbStressTest.tap ............. ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbCaStatsTest.tap ............ ok
dbCaLinkTest.tap ............. ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
dbStaticTest.tap ............. ok
Files=19, Tests=2790,  1 wallclock secs ( 0.66 usr  0.07 sys +  0.00 cusr  0.04 csys =  0.77 CPU)
Result: PASS
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/db/test/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/db/test'>
make -C ioc/dbtemplate/test test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/dbtemplate/test'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/dbtemplate/test/O.linux-x86'>
prove --failures --ext .tap --exec cat --color msi.tap
msi.tap .. ok
Files=1, Tests=9,  0 wallclock secs ( 0.04 usr +  0.00 sys =  0.04 CPU)
Result: PASS
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/dbtemplate/test/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/ioc/dbtemplate/test'>
make -C ./std test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/O.linux-x86'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std'>
make -C std/filters/test test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/filters/test'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/filters/test/O.linux-x86'>
prove --failures --ext .tap --exec cat --color tsTest.tap dbndTest.tap arrTest.tap syncTest.tap
tsTest.tap .... ok
dbndTest.tap .. ok
arrTest.tap ... ok
syncTest.tap .. ok
Files=4, Tests=1612,  1 wallclock secs ( 0.38 usr +  0.02 sys =  0.40 CPU)
Result: PASS
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/filters/test/O.linux-x86'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/filters/test'>
make -C std/rec/test test-results
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/rec/test'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/rec/test/O.linux-x86'>
prove --failures --ext .tap --exec cat --color arrayOpTest.tap recMiscTest.tap linkRetargetLinkTest.tap linkInitTest.tap compressTest.tap asTest.tap analogMonitorTest.tap regressTest.tap
arrayOpTest.tap ........... ok
recMiscTest.tap ........... ok
linkRetargetLinkTest.tap .. ok
linkInitTest.tap ..........
not ok 59 - dbGetField("i64i2", 7) -> 4294967297 == 1
Failed 1/72 subtests
compressTest.tap .......... ok
asTest.tap ................ ok
analogMonitorTest.tap ..... ok
regressTest.tap ........... ok
Test Summary Report
linkInitTest.tap        (Wstat: 0 Tests: 72 Failed: 1)
  Failed test:  59
Files=8, Tests=2077,  0 wallclock secs ( 0.45 usr  0.03 sys +  0.00 cusr  0.01 csys =  0.49 CPU)
Result: FAIL
make[3]: *** [test-results] Error 1
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/rec/test/O.linux-x86'>
make[2]: *** [test-results.linux-x86] Error 2
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/rec/test'>
make[1]: *** [std/rec/test.test-results] Error 2
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src'>
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86/*.tap
Saving reports...
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Build failed in Jenkins: epics-base-3.16-linux32-test #79 APS Jenkins
Build failed in Jenkins: epics-base-3.16-linux32-test #77 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-linux32-test #77 APS Jenkins
Next: Jenkins build became unstable: epics-base-3.16-sol-test #80 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Build failed in Jenkins: epics-base-3.16-linux32-test #79 APS Jenkins
ANJ, 24 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
