Hi Ernest,
On 2012-05-15 Ernest L. Williams Jr. wrote:
> We are not using the product from WRS.
> So, we will propose a different name.
> How about "linuxRT-x86" and "linuxRT-ppcP2020" ?
Linux/RT was a /different/ commercial real-time Linux distribution from
TimeSys, although they may be dead now for all I know. The name Linux-rt is
also used for the generic real-time linux community that maintain the
CONFIG_PREEMPT_RT patches for the kernel.org kernel.
> > Will these targets be using the standard Linux OS_CLASS or do they
> > require their own versions of the OS-dependent files under
> > src/libCom/osi/os?
> We are using the standard Linux "OS_CLASS"
If you're just using the standard code from Base without changing any of it
then all you really need is to create local (SLAC-specific) aliases for the
linux-x86 and linux-ppc targets. In that case you can call them whatever you
like since they don't have to make their way into the official Base release.
I would recommend that you try to avoid CPU-specific target names like
linuxRT-ppcP2020 unless you really need them. It is usually sufficient to
configure gcc to build for the generic CPU family, unless you're writing
highly tuned CPU-specific kernel-level code. You won't want to have to
compile everything for multiple CPU-specific architectures if all your CPUs
can run generic linuxRT-ppc binaries instead.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: New RTOS cross with linux+RT_PREEMPT patch Ernest L. Williams Jr.
- New RTOS cross with linux+RT_PREEMPT patch Ernest L. Williams Jr.
- Re: New RTOS cross with linux+RT_PREEMPT patch Andrew Johnson
<2012>
<2012>
