2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: [Bug 737632] [NEW] EPICS_TIMEZONE and osi*Time providers not documented
To: [email protected]
Date: Fri, 18 Mar 2011 15:52:47 -0000
Public bug reported:
There have been a number of changes to the environment parameters since
section 7.8 was last revised.
There needs to be documentation on the osiClockTime and osiNTPTime time
providers, and the use of the EPICS_TIMEZONE parameter on vxWorks, and
how this works on RTEMS.
** Affects: epics-appdev
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Application Developers'
Guide.
https://bugs.launchpad.net/bugs/737632
Title:
Status in EPICS Application Developers' Guide:
  New
Bug description:
  since section 7.8 was last revised.
  time providers, and the use of the EPICS_TIMEZONE parameter on
  vxWorks, and how this works on RTEMS.
[Bug 737632] [NEW] EPICS_TIMEZONE and osi*Time providers not documented Andrew Johnson
[Bug 737632] Re: EPICS_TIMEZONE and osi*Time providers not documented Eric Norum
Prev: Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Ralph Lange
Next: [Bug 737632] Re: EPICS_TIMEZONE and osi*Time providers not documented Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: EPICS internals talks? nick.rees
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
