Subject: |
[Bug 737632] Re: EPICS_TIMEZONE and osi*Time providers not documented |
Eric Norum <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 18 Mar 2011 18:16:26 -0000 |
On RTEMS the TZ environment variable can be used to set the time zone information and the dates at which to switch between standard and daylight-savings time. The following example applies to Chicago for the daylight-savings times rules in effect for 2011:
epicsEnvSet TZ "CST6CDT,M 3.2.0,M 11.1.0"
This sets the standard time name to CST and the daylight-savings time name to CDT. Standard time is 6 hours behind GMT. Daylight savings begins on the 0th day (Sunday) of the second week of the third month and ends on Sunday of the first week of the eleventh month.
The command
epicsEnvSet TZ "CST6"
is applicable for Saskatchewan which stays on Central Standard Time all year.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Application Developers'
Guide.
https://bugs.launchpad.net/bugs/737632
Title:
Status in EPICS Application Developers' Guide:
New
Bug description:
There have been a number of changes to the environment parameters
since section 7.8 was last revised.
There needs to be documentation on the osiClockTime and osiNTPTime
time providers, and the use of the EPICS_TIMEZONE parameter on
vxWorks, and how this works on RTEMS.
- [Bug 737632] [NEW] EPICS_TIMEZONE and osi*Time providers not documented Andrew Johnson
Re: ASIO and RTEMS Michael Davidsaver
<2011>
RE: EPICS internals talks? nick.rees
<2011>
