2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Error in creating the example application
To: [email protected]
Date: Thu, 28 Oct 2010 11:50:14 +0800 (CST)
Hi,guys
I have just installed the base-3-14-11 on openSUSE10.0.And then i want to creat the example application,i fail and do not konw why.look for you help,thanks!
there are the codes below:
linux:/home/xy/EPICS # mkdir iocApps
linux:/home/xy/EPICS # cd iocApps
linux:/home/xy/EPICS/iocApps # /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeBaseApp.pl -t example EXP
linux:/home/xy/EPICS/iocApps # /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeBaseApp.pl -i -t example EXP
The following target architectures are available in base:
    linux-686
    linux-x86
What architecture do you want to use? linux-x86
The following applications are available:
    EXP
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name? EXP
linux:/home/xy/EPICS/iocApps # EPICS_HOST_ARCH=linux-x86 make
make -C ./configure install
make[1]: Entering directory `/home/xy/EPICS/iocApps/configure'
perl /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..perl /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-686 ../..mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
make[2]: Entering directory `/home/xy/EPICS/iocApps/configure/O.linux-x86'
/home/xy/EPICS/base-3-14-11/configure/CONFIG_APP_INCLUDE:20: *** miss“endif”。 stop。
make[2]: Leaving directory `/home/xy/EPICS/iocApps/configure/O.linux-x86'
make[1]: *** [install.linux-x86] error 2
make[1]: Leaving directory `/home/xy/EPICS/iocApps/configure'
make: *** [configure.install] error 2
Re: Error in creating the example application Janet Anderson
Re: Error in creating the example application Andrew Johnson
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Ben F.
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Lookup table problem Ben Franksen
Next: Re: Error in creating the example application Janet Anderson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
