On Wednesday 27 October 2010 22:50:14 xyz140406 wrote:
> I have just installed the base-3-14-11 on openSUSE10.0.And then i want to
> creat the example application,i fail and do not konw why.look for you
> help,thanks! there are the codes below:
> make[1]: Entering directory `/home/xy/EPICS/iocApps/configure'
> perl /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-x86
> ../..perl /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeMakefile.pl
> O.linux-686 ../..mkdir O.Common make -C O.linux-x86 -f ../Makefile
> TOP=../.. T_A=linux-x86 install make[2]: Entering directory
> `/home/xy/EPICS/iocApps/configure/O.linux-x86'
> /home/xy/EPICS/base-3-14-11/configure/CONFIG_APP_INCLUDE:20: ***
> miss“endif”。 stop。 make[2]: Leaving directory
What version of gnumake is installed on your system? The EPICS 3.14.11 build
system requires at least GNU Make 3.81, and I suspect openSUSE-10.0 may be too
old for that version, resulting in the above error. Use "make --version" to
find out.
- Andrew
PS: Please use the tech-talk mailing list for questions like this in the
future, core-talk is for EPICS developers to have technical discussions. We
would also appreciate it if you would include a name that we can identify you
by, "xyz140406" is somewhat inhuman.
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Error in creating the example application xyz140406
Re: Error in creating the example application Janet Anderson
[Bug 668067] [NEW] documentation of libCom/osi/epicsEvent unclear Ben Franksen
<2010>
Re: epicsEvent Ralph Lange
<2010>
