2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base
To: [email protected]
Date: Wed, 27 Oct 2010 21:52:40 -0000
On Mittwoch, 27. Oktober 2010, Dirk Zimoch wrote:
> I tested long event names like "Event with a very long name number
> 123" (up to 38 chars, the first 35 of them the same for all 255
> events) named-soft-events
>   3.145 seconds
> named-soft-events2
>   2.381 seconds
> More or less the same as with short event names. (Numbers vary a bit
> from turn to turn)
Interesting. I'd have expected the ratio between the two versions to
increase for longer strings. I did some research and found that gcc
heavily optimises strcmp, resulting (on certain architectures) in
machine code that uses 16-byte instructions, see
http://stackoverflow.com/questions/1128096/c-string-comparison-in-one-clock-cycle
You learn a bit more every day...
Cheers
Ben
"Never confuse what is natural with what is habitual."
                                   -- attributed to Mahatma Gandhi
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/26190
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base.
Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Prev: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Next: Error in creating the example application xyz140406
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
