Subject: |
Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base |
Ben Franksen <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 14 May 2010 21:51:29 +0200 |
On Freitag, 14. Mai 2010, Andrew Johnson wrote:
> On Friday 14 May 2010 12:54:10 Ben Franksen wrote:
> > I am astonished. Does Bazaar not have an equivalent of 'darcs
> > unrecord'?
> It does, 'bzr uncommit' will remove the last committed revision, although
> it's not recommended to use it on a public repository where other people
> may have grabbed a copy of that revision. I this case though I believe
> Jeff was talking about commits he made using CVS to the main trunk,
> before we switched to Bazaar.
If this is the case I apologize for spamming the list with irrelevancies.
> With Bazaar he could also use 'bzr merge --uncommitted' to pull copies of
> any *uncommitted* changes from his work branch to the home machine
> (assuming he has ssh or sftp access to work from home), thus avoiding the
> need to commit a dummy revision.
Nice feature.
Cheers
Ben
"One must never confuse what is natural with what is habitual."
Mahatma Gandhi
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Jeff Hill
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ben Franksen
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Andrew Johnson
Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Benjamin Franksen
sequencer beta release Benjamin Franksen
<2010>
Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ralph Lange
<2010>
