2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base
To: [email protected]
Date: Fri, 14 May 2010 14:01:41 -0500
On Friday 14 May 2010 13:33:45 Ralph Lange wrote:
> On Fri 14 May 2010 14:28:29 Andrew Johnson wrote:
> > With Bazaar he could also use 'bzr merge --uncommitted' to pull copies of
> > any *uncommitted* changes from his work branch to the home machine
> > (assuming he has ssh or sftp access to work from home), thus avoiding the
> > need to commit a dummy revision.
> Wow, that's a neat feature. Didn't know that one.
It's *really useful if you've created a bug fix on a development branch which
already has committed changes (that are not ready to merge yet) but you want
to try out or commit the fix on the official branch or on some other branch.
'bzr shelve' is also very useful for managing uncommitted changes within a
single branch, especially if you want to merge the latest official patches
into a branch without committing your current changes.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Jeff Hill
Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Andrew Johnson
Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ralph Lange
Next: Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ben Franksen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
