On Friday 14 May 2010 12:54:10 Ben Franksen wrote:
> I am astonished. Does Bazaar not have an equivalent of 'darcs unrecord'?
It does, 'bzr uncommit' will remove the last committed revision, although it's
not recommended to use it on a public repository where other people may have
grabbed a copy of that revision. I this case though I believe Jeff was
talking about commits he made using CVS to the main trunk, before we switched
to Bazaar.
With Bazaar he could also use 'bzr merge --uncommitted' to pull copies of any
*uncommitted* changes from his work branch to the home machine (assuming he
has ssh or sftp access to work from home), thus avoiding the need to commit a
dummy revision.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ralph Lange
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ben Franksen
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Jeff Hill
<2010>
<2010>
