2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: proper thread cleanup on Linux?
To: "'Core-Talk'" <[email protected]>
Date: Tue, 25 Aug 2009 16:09:14 -0600
After further testing on newer linux versions where the debugger seems to actually function correctly I now strongly suspect that this issue is caused by this change. The symptom is that two threads that CA creates to manage TCP circuits never shutdown. They need to shutdown typically when the TCP circuit disconnects or when the last channel on the circuit is deleted. The bug was introduced in R3.14.9. See mantis 363.
cvs diff -r 1.2 -r 1.2.2.1 -wb -- systemCallIntMech.cpp systemCallIntMech.cpp (in directory C:\hill\R3.14.dll_hell_fix\epics\base\src\libCom\osi\os\posix\)
Index: systemCallIntMech.cpp
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/osi/os/posix/systemCallIntMech.cpp,v
retrieving revision 1.2
retrieving revision 1.2.2.1
diff -u -b -w -b -r1.2 -r1.2.2.1
--- systemCallIntMech.cpp     1 May 2003 22:11:42 -0000     1.2
+++ systemCallIntMech.cpp     14 May 2004 13:36:01 -0000    1.2.2.1
@@ -8,7 +8,7 @@
 * and higher are distributed subject to a Software License Agreement found
 * in file LICENSE that is included with this distribution.
-/* $Id: systemCallIntMech.cpp,v 1.2 2003/05/01 22:11:42 jhill Exp $ */
+/* $Id: systemCallIntMech.cpp,v 1.2.2.1 2004/05/14 13:36:01 norume Exp $ */
  *      Author:        Jeff Hill
@@ -18,5 +18,5 @@
 enum epicsSocketSystemCallInterruptMechanismQueryInfo
         epicsSocketSystemCallInterruptMechanismQuery ()
-    return esscimqi_socketSigAlarmRequired;
+    return esscimqi_socketBothShutdownRequired;
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
From: [email protected] [mailto:[email protected]] On Behalf Of Jeff Hill
Sent: Tuesday, August 25, 2009 12:31 PM
To: 'Core-Talk'
Subject: proper thread cleanup on Linux?
All,
On our Linux (2.4.21-52.ELsmp) test system with R3.14 latest, I see a very strange behavior when I run my CA client side regression tests - acctst. The symptom is an accumulating number of threads with odd stack traces (see below). The test doesn’t fail, but the system slows to a crawl as it runs low on threads (resources). Since these threads are not executing anywhere in EPICS code, the cause is a complete mystery. Does anyone recognize this symptom; perhaps as being the symptom of the problem on Linux where a c++ exception handler is catching all exceptions - including some Linux implementation of pthreads thread exit exception? I don’t reproduce this issue running on Linux (2.6.9-42.0.3.ELsmp) with R3.14.8.2.
(gdb) thread 1146
[Switching to thread 1146 (Thread -1219617872 (LWP 28422))]#0  0x0013c939 in __lll_mutex_lock_wait () from /lib/tls/libpthread.so.0
(gdb) bt
#1  0x00138b21 in _L_mutex_lock_949 () from /lib/tls/libpthread.so.0
#2  0x00000000 in ?? ()
This is the Linux version:
~/epicsR3.14/epics/extensions/src/gateway$ uname -a
Linux santana 2.4.21-52.ELsmp #1 SMP Tue Sep 25 15:13:04 EDT 2007 i686 i686 i386 GNU/Linux
This is the gdb version (this gdb is known to have some issues):
~/epicsR3.14/epics/extensions/src/gateway$ gcc -v
Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --with-system-zlib --enable-__cxa_atexit --host=i386-redhat-linux
Thread model: posix
gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-59)
In the debugger I see that threads are being created and destroyed in matched sets as they should be while the test is running (see a sample of some of the output below).
[New Thread -1521730640 (LWP 2504)]
[New Thread -1521464400 (LWP 2506)]
[New Thread -1520669776 (LWP 2508)]
[New Thread -1522787408 (LWP 2510)]
[New Thread -1523582032 (LWP 2512)]
[Thread -1522787408 (LWP 2510) exited]
[Thread -1520669776 (LWP 2508) exited]
[Thread -1521464400 (LWP 2506) exited]
[Thread -1521730640 (LWP 2504) exited]
[Thread -1523582032 (LWP 2512) exited]
Have you seen this behavior? Is something wrong with my version of Linux?
To reproduce this run in two different windows:
excas –p myTest:
acctst myTest:bill 10
or alternativelyin gdb (you will need to build w/o optimization):
gdb acctst
run myTest:bill 10
^c
info threads
thread <nnnn>
bt
Jeff
[email protected]
Re: proper thread cleanup on Linux? Andrew Johnson
proper thread cleanup on Linux? Jeff Hill
Prev: Re: proper thread cleanup on Linux? Andrew Johnson
Next: Re: proper thread cleanup on Linux? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
