2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: proper thread cleanup on Linux?
To: [email protected]
Date: Tue, 25 Aug 2009 17:53:29 -0500
Hi Jeff,
On Tuesday 25 August 2009 17:09:14 Jeff Hill wrote:
> After further testing on newer linux versions where the debugger seems to
> actually function correctly I now strongly suspect that this issue is
> caused by this change. The symptom is that two threads that CA creates to
> manage TCP circuits never shutdown. They need to shutdown typically when
> the TCP circuit disconnects or when the last channel on the circuit is
> deleted. The bug was introduced in R3.14.9. See mantis 363.
Can you write a version of blockingSockTest that demonstrates this and
correctly responds with socketSigAlarmRequired?  Unfortunately you'll have to
test it against R3.14.9 or R3.14.10 — I eviscerated the sigAlarm routines for
this release since our use of this signal broke the posix timer library
(which relies on SIG_ALARM) that some external libraries use.  We'll have to
switch to using a different signal if we're going to bring it back (we
probably should make the signal number we use configurable).
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: proper thread cleanup on Linux? Jeff Hill
Prev: RE: proper thread cleanup on Linux? Jeff Hill
Next: RE: proper thread cleanup on Linux? Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
