2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: proper thread cleanup on Linux?
To: "'Core-Talk'" <[email protected]>
Date: Tue, 25 Aug 2009 12:30:54 -0600
All,
On our Linux (2.4.21-52.ELsmp) test system with R3.14 latest, I see a very strange behavior when I run my CA client side regression tests - acctst. The symptom is an accumulating number of threads with odd stack traces (see below). The test doesn’t fail, but the system slows to a crawl as it runs low on threads (resources). Since these threads are not executing anywhere in EPICS code, the cause is a complete mystery. Does anyone recognize this symptom; perhaps as being the symptom of the problem on Linux where a c++ exception handler is catching all exceptions - including some Linux implementation of pthreads thread exit exception? I don’t reproduce this issue running on Linux (2.6.9-42.0.3.ELsmp) with R3.14.8.2.
(gdb) thread 1146
[Switching to thread 1146 (Thread -1219617872 (LWP 28422))]#0  0x0013c939 in __lll_mutex_lock_wait () from /lib/tls/libpthread.so.0
(gdb) bt
#1  0x00138b21 in _L_mutex_lock_949 () from /lib/tls/libpthread.so.0
#2  0x00000000 in ?? ()
This is the Linux version:
~/epicsR3.14/epics/extensions/src/gateway$ uname -a
Linux santana 2.4.21-52.ELsmp #1 SMP Tue Sep 25 15:13:04 EDT 2007 i686 i686 i386 GNU/Linux
This is the gdb version (this gdb is known to have some issues):
~/epicsR3.14/epics/extensions/src/gateway$ gcc -v
Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --with-system-zlib --enable-__cxa_atexit --host=i386-redhat-linux
Thread model: posix
gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-59)
In the debugger I see that threads are being created and destroyed in matched sets as they should be while the test is running (see a sample of some of the output below).
[New Thread -1521730640 (LWP 2504)]
[New Thread -1521464400 (LWP 2506)]
[New Thread -1520669776 (LWP 2508)]
[New Thread -1522787408 (LWP 2510)]
[New Thread -1523582032 (LWP 2512)]
[Thread -1522787408 (LWP 2510) exited]
[Thread -1520669776 (LWP 2508) exited]
[Thread -1521464400 (LWP 2506) exited]
[Thread -1521730640 (LWP 2504) exited]
[Thread -1523582032 (LWP 2512) exited]
Have you seen this behavior? Is something wrong with my version of Linux?
To reproduce this run in two different windows:
excas –p myTest:
acctst myTest:bill 10
or alternativelyin gdb (you will need to build w/o optimization):
gdb acctst
run myTest:bill 10
^c
info threads
thread <nnnn>
bt
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
Re: proper thread cleanup on Linux? Andrew Johnson
RE: proper thread cleanup on Linux? Jeff Hill
Prev: Re: VWTime driver Andrew Johnson
Next: Re: proper thread cleanup on Linux? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
