On May 2, 2008, at 10:22 AM, Till Straumann wrote:
It just seems that rtems_netconfig.c mixes functionality of
initializing RTEMS
(networking, console, ...) and initializing EPICS (some generic
things, some
os/RTEMS specific).
How so?
As far as I can tell, rtems_netconfig.c contains nothing but the
network configuration structures.
At least that's all that I intended it to contain.
IMO it would be useful to break the two apart so that users
implementing
their own RTEMS initialization can still use the pieces that deal
with initializing
EPICS (w/o having to copy/paste from rtems_netconfig.c)
For network configuration, the hooks mentioned in the release notes
should be all that's needed to implement custom tweaks (no copying of
rtems_netconfig.c required). For example, our BPM embedded IOCs set
all their network configuration based on the setting of front-panel
switches.
There are no corresponding hooks for RTEMS configuration at the
moment, though.
- Till
- Andrew
Eric Norum wrote:
There are some mechanisms already available.
1) EPICS RTEMS support breaks the configuration/initialization
into several source files. If, for example, your application
requires some specialized network configuration, simply copy
rtems_netconfig.c to the application directory, make the changes,
and add rtems_netconfig.c to the application Makefile. To do this
on a site-wide basis, put your site-specific version of
rtems_netconfig.o into a support module where it will be linked
before -lrtemsCom is encountered. There's a separate
rtems_config.c file, too.
2) As noted in the EPICS R3.14.10 release notes, there are some
hooks to make it easier to set up your own specific configuration:
Added hooks for application routines to supply special network
configuration parameters. The RTEMS startup code calls
epicsRtemsInitPreSetBootConfigFromNVRAM just before reading
values from NVRAM and epicsRtemsInitPostSetBootConfigFromNVRAM
just afterwards. See epicsRtemsInitHooks.h for prototypes and
global variables.
seems that 3.14.10 does a more initialization in the 'Init'
function
which we don't use (e.g., because it hardcodes things like the
the
amount of mbuf (networking buffers) space [which ends up
being the same] and whether BOOTP should be used.
IMHO we should come up with a better way of initializing the
system
that is more flexible (here we use a bootloader plus a small
library
for connecting the bootloader, user interactive input, non-
volatile memory
and the bootee).
For the time being, IMHO 'Init' should be broken up into pieces
that
a) deal with initializing RTEMS (networking, filesystem, console)
b) deal with initializing EPICS (setting some environment
variables,
rtemsTicksPerSecond_double etc.)
The user should be able to override all of (a) but use (b) to
initialize
EPICS on an RTEMS system of her preference.
That seems entirely reasonable, can you work with Eric to come up
with a proposal and patch that works for both camps? R3.14.10 is
not set in stone yet, and it would be good to get this cleared up
before the release.
- Andrew
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: Unresolved symbol: rtemsTicksPerSecond_double Till Straumann
- Re: Unresolved symbol: rtemsTicksPerSecond_double Andrew Johnson
<2008>
<2008>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
