Till, Ernest,
Does what Eric describes provide what you guys need? The EPICS
rtems_netconfig.c file is really an application-specific network
configuration file so in many cases you may need to have your own anyway.
- Andrew
Eric Norum wrote:
There are some mechanisms already available.
1) EPICS RTEMS support breaks the configuration/initialization into
several source files. If, for example, your application requires some
specialized network configuration, simply copy rtems_netconfig.c to the
application directory, make the changes, and add rtems_netconfig.c to
the application Makefile. To do this on a site-wide basis, put your
site-specific version of rtems_netconfig.o into a support module where
it will be linked before -lrtemsCom is encountered. There's a separate
rtems_config.c file, too.
2) As noted in the EPICS R3.14.10 release notes, there are some hooks to
make it easier to set up your own specific configuration:
Added hooks for application routines to supply special network
configuration parameters. The RTEMS startup code calls
epicsRtemsInitPreSetBootConfigFromNVRAM just before reading values
from NVRAM and epicsRtemsInitPostSetBootConfigFromNVRAM just
afterwards. See epicsRtemsInitHooks.h for prototypes and global
variables.
On May 1, 2008, at 4:10 PM, Andrew Johnson wrote:
Till Straumann wrote:
seems that 3.14.10 does a more initialization in the 'Init' function
which we don't use (e.g., because it hardcodes things like the the
amount of mbuf (networking buffers) space [which ends up
being the same] and whether BOOTP should be used.
IMHO we should come up with a better way of initializing the system
that is more flexible (here we use a bootloader plus a small library
for connecting the bootloader, user interactive input, non-volatile
memory
and the bootee).
For the time being, IMHO 'Init' should be broken up into pieces
that
a) deal with initializing RTEMS (networking, filesystem, console)
b) deal with initializing EPICS (setting some environment variables,
rtemsTicksPerSecond_double etc.)
The user should be able to override all of (a) but use (b) to
initialize
EPICS on an RTEMS system of her preference.
That seems entirely reasonable, can you work with Eric to come up with
a proposal and patch that works for both camps? R3.14.10 is not set
in stone yet, and it would be good to get this cleared up before the
release.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- Re: Unresolved symbol: rtemsTicksPerSecond_double Till Straumann
Re: NDEBUG Ben Franksen
<2008>
<2008>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
