2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Unresolved symbol: rtemsTicksPerSecond_double
Cc: Steve Shoaf <[email protected]>, Arturo Alarcon <[email protected]>, EPICS core-talk <[email protected]>, "Ernest L. Williams Jr." <[email protected]>, [email protected]
Date: Fri, 02 May 2008 08:22:20 -0700
Andrew Johnson wrote:
Till, Ernest,
Does what Eric describes provide what you guys need? The EPICS rtems_netconfig.c file is really an application-specific network configuration file so in many cases you may need to have your own anyway.
It just seems that rtems_netconfig.c mixes functionality of initializing RTEMS
(networking, console, ...) and initializing EPICS (some generic things, some
os/RTEMS specific).
IMO it would be useful to break the two apart so that users implementing
their own RTEMS initialization can still use the pieces that deal with initializing
EPICS (w/o having to copy/paste from rtems_netconfig.c).
- Till
- Andrew
Eric Norum wrote:
There are some mechanisms already available.
1) EPICS RTEMS support breaks the configuration/initialization into several source files. If, for example, your application requires some specialized network configuration, simply copy rtems_netconfig.c to the application directory, make the changes, and add rtems_netconfig.c to the application Makefile. To do this on a site-wide basis, put your site-specific version of rtems_netconfig.o into a support module where it will be linked before -lrtemsCom is encountered. There's a separate rtems_config.c file, too.
2) As noted in the EPICS R3.14.10 release notes, there are some hooks to make it easier to set up your own specific configuration:
Added hooks for application routines to supply special network configuration parameters. The RTEMS startup code calls epicsRtemsInitPreSetBootConfigFromNVRAM just before reading values from NVRAM and epicsRtemsInitPostSetBootConfigFromNVRAM just afterwards. See epicsRtemsInitHooks.h for prototypes and global variables.
On May 1, 2008, at 4:10 PM, Andrew Johnson wrote:
Till Straumann wrote:
seems that 3.14.10 does a more initialization in the 'Init' function
which we don't use (e.g., because it hardcodes things like the the
amount of mbuf  (networking buffers) space [which ends up
being the same] and whether BOOTP should be used.
IMHO we should come up with a better way of initializing the system
that is more flexible (here we use a bootloader plus a small library
for connecting the bootloader, user interactive input, non-volatile memory
and the bootee).
For the time being, IMHO 'Init' should be broken up into pieces
that
a) deal with initializing RTEMS (networking, filesystem, console)
b) deal with initializing EPICS (setting some environment variables,
   rtemsTicksPerSecond_double etc.)
The user should be able to override all of (a) but use (b) to initialize
EPICS on an RTEMS system of her preference.
That seems entirely reasonable, can you work with Eric to come up with a proposal and patch that works for both camps? R3.14.10 is not set in stone yet, and it would be good to get this cleared up before the release.
- Andrew
Re: Unresolved symbol: rtemsTicksPerSecond_double Eric Norum
Re: Unresolved symbol: rtemsTicksPerSecond_double Andrew Johnson
Prev: Re: Unresolved symbol: rtemsTicksPerSecond_double Andrew Johnson
Next: Re: Unresolved symbol: rtemsTicksPerSecond_double Eric Norum
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
