Liu, Gongfa wrote:
The following is the email copied from [email protected]. The
compiler error is same in our case. Maybe this compiler error can be
ignored here since it is not related to the redundancy patch.
> From: Graham Waters [mailto:[email protected]]
> /usr2/tornado/release/2.2.1/x86/host/sun4-solaris2/bin/ccpentium -c
> -D_POSIX_SOURCE -DCPU=PENTIUM -D_X86_ -DvxWorks -include
> /usr2/tornado/release/2.2.1/x86/target/h/vxWorks.h -ansi -O3 -Wall
> -mpentium -fno-defer-pop -x 'c++' -fno-implicit-templates
> -fno-builtin -I. -I.. -I../../../include/os/vxWorks -I../../../include
> -I/usr2/tornado/release/2.2.1/x86/target/h ../iocsh.cpp
> ..../iocsh.cpp: In function `void iocshRegisterVariable (const
> iocshVarDef
> ..../iocsh.cpp:133: Internal compiler error in `expand_expr', at
> expr.c:5996
Ok, we think that the Pentium compiler may have an internally defined
macro called 'varArgs', which is the name of the variable at the error
location. Please try this patch (the diff is against the original
R3.14.9 file), which instead renames that group of variables:
Index: iocsh.cpp
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/iocsh/Attic/iocsh.cpp,v
retrieving revision 1.9.2.35
diff -u -b -r1.9.2.35 iocsh.cpp
--- iocsh.cpp 12 Dec 2006 21:04:19 -0000 1.9.2.35
+++ iocsh.cpp 19 Nov 2007 16:53:58 -0000
@@ -147,10 +147,10 @@
struct iocshVariable *l, *p, *n;
int i;
int found;
- static const iocshArg varArg0 = { "[variable",iocshArgString};
- static const iocshArg varArg1 = { "[value]]",iocshArgString};
- static const iocshArg *varArgs[2] = {&varArg0, &varArg1};
- static const iocshFuncDef varFuncDef = {"var",2,varArgs};
+ static const iocshArg varCmdArg0 = { "[variable",iocshArgString};
+ static const iocshArg varCmdArg1 = { "[value]]",iocshArgString};
+ static const iocshArg *varCmdArgs[2] = {&varCmdArg0, &varCmdArg1};
+ static const iocshFuncDef varFuncDef = {"var",2,varCmdArgs};
iocshTableLock ();
while ((piocshVarDef != NULL)
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- Re: Redundancy Patch: iocsh Liu, Gongfa
- Redundancy Patch: iocsh Andrew Johnson
- Re: Redundancy Patch: iocsh Andrew Johnson
Re: Redundancy Patch: makeBaseApp Liu, Gongfa
<2007>
<2007>
