2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Redundancy Patch: iocsh
To: EPICS core-talk <[email protected]>
Date: Thu, 15 Nov 2007 17:36:46 -0600
Modified
# source files
(5) base-3.14.9/src/iocsh/iocsh.cpp
    Change the definition of varArgs[2] in function
    iocshRegisterVariable because there is compiling error with
    tornado 2.2.1.This solution is from TRIUMF.
Index: src/iocsh/iocsh.cpp
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/iocsh/Attic/iocsh.cpp,v
retrieving revision 1.9.2.35
diff -u -b -r1.9.2.35 iocsh.cpp
--- src/iocsh/iocsh.cpp	12 Dec 2006 21:04:19 -0000	1.9.2.35
+++ src/iocsh/iocsh.cpp	12 Nov 2007 18:22:33 -0000
@@ -12,6 +12,15 @@
 /* Heavily modified by Eric Norum   Date: 03MAY2000 */
 /* Adapted to C++ by Eric Norum   Date: 18DEC2000 */
+modification history
+Oct.16,2007,Gongfa Liu  change the definition of varArgs[2] in function
+                        iocshRegisterVariable because there is compiling
+                        error with tornado 2.2.1.
+                        This solution is from TRIUMF.
 #include <stddef.h>
 #include <string.h>
 #include <stdio.h>
@@ -149,7 +158,12 @@
     int found;
     static const iocshArg varArg0 = { "[variable",iocshArgString};
     static const iocshArg varArg1 = { "[value]]",iocshArgString};
-    static const iocshArg *varArgs[2] = {&varArg0, &varArg1};
+/* TRIUMF REPLACE THIS    static const iocshArg *varArgs[2] = {&varArg0, &varArg1}; */
+   static const iocshArg *varArgs[2];
+   varArgs[0] = &varArg0;
+   varArgs[1] = &varArg1;
+    /*static const iocshArg *varArgs[2] = {&varArg0, &varArg1};*/
     static const iocshFuncDef varFuncDef = {"var",2,varArgs};
     iocshTableLock ();
Re: Redundancy Patch: iocsh Andrew Johnson
Prev: Redundancy Patch: db Andrew Johnson
Next: Redundancy Patch: rsrv Andrew Johnson
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Redundancy Patch: db Liu, Gongfa
Next: Re: Redundancy Patch: iocsh Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
