Hi, Andrew,
Andrew Johnson wrote:
Modified
# source files
(16) base-3.14.9/src/makeBaseApp/top/configure/RELEASE
The following lines are added for supporting iocRedundancy package:
#If using iocRedundacy package, point REDUNDANCY at its top
directory:
#REDUNDANCY=$(EPICS_BASE)/../modules/soft/iocRedundancy
(17) base-3.14.9/src/makeBaseApp/top/exampleApp/src/Makefile
The following lines are added for building redundant IOC application:
# NOTE: To build redundant IOC application, REDUNDANCY must be
defined
# in the <top>/configure/RELEASE file
ifneq ($(REDUNDANCY),)
_APPNAME__DBD += rmt.dbd
_APPNAME__DBD += cce.dbd
_APPNAME__DBD += snlexec.dbd
_APPNAME__LIBS += rmt
_APPNAME__LIBS += cce
_APPNAME__LIBS += snlexec
endif
I don't see the need to include links to the redundancy subsystem in the
makeBaseApp example template; the majority of EPICS users won't be using
the redundancy system, and I'd prefer not to confuse beginners with
information that is of no use them (that being the main purpose of the
makeBaseApp templates).
The additions necessary to create a redundant IOC just need to be
documented with the redundancy system, which could provide its own
makeBaseApp templates if it desires (makeBaseApp.pl can be told to look
in a different location for its templates).
Have you tested building a redundant IOC without an entry for SNCSEQ in
its configure/RELEASE file? I suspect the above would not be sufficient
to cover this case, assuming it is possible to build such an IOC.
Yes, you are right. It does not cover the case without an entry for
SNCSEQ. The original purpose is that it is convenient for redundancy
users. The modification can be ignored if it confuses non-redundancy
beginners.
Bernd Schoeneburg and Gongfa Liu
Gongfa Liu MKS-2, DESY
phone: +49-40-8998-1642 Notkestr. 85
fax: +49-40-8998-4388 22607 Hamburg
e-mail: [email protected] Germany
- Redundancy Patch: makeBaseApp Andrew Johnson
- Re: Redundancy Patch: makeBaseApp Andrew Johnson
Re: Redundancy Patch: iocsh Liu, Gongfa
Re: Redundancy Patch: iocsh Andrew Johnson
<2007>
[Fwd: Re: Timing/Event Systems] Andrew Johnson
<2007>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
