Subject: |
Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" |
"Ernest L. Williams Jr." <[email protected]> |
To: |
Marty Kraimer <[email protected]> |
Cc: |
EPICS Core Talk <[email protected]> |
Date: |
Mon, 21 Nov 2005 12:14:18 -0500 |
On Mon, 2005-11-21 at 09:11 -0600, Marty Kraimer wrote:
> Does it still happen with the latest committs to posix/osdThread.c?
> Does this happen whenever you exit or only at random?
Hi Marty,
I have updated with your latest changes.
This happens every time I exit. The details with a stack trace are
below:
epics> epicsThreadShowAll
NAME EPICS ID PTHREAD ID OSIPRI OSSPRI STATE
_main_ 0x505d20 0 0 0 OK
errlog 0x50b280 1073875296 10 10 OK
taskwd 0x57a580 1074010464 10 10 OK
timerQueue 0x512260 1074276704 70 69 OK
cbLow 0x578960 1074805088 59 58 OK
cbMedium 0x511840 1075333472 64 63 OK
cbHigh 0x511ad0 1075861856 71 70 OK
dbCaLink 0x57bb30 1076390240 50 50 OK
scanOnce 0x5879f0 1076918624 70 69 OK
scan10 0x588200 1077447008 60 59 OK
scan5 0x588400 1077975392 61 60 OK
scan2 0x588600 1078503776 62 61 OK
scan1 0x588800 1079032160 63 62 OK
scan0.5 0x588a00 1079560544 64 63 OK
scan0.2 0x588c00 1080088928 65 64 OK
scan0.1 0x588e00 1080617312 66 65 OK
CAC-event 0x5b91b0 1080883552 52 51 OK
CAS-TCP 0x5c60e0 1081149792 16 16 OK
CAS-beacon 0x5c6300 1081284960 14 14 OK
CAS-UDP 0x5c6590 1081551200 12 12 OK
epics> exit
epicsThread: Unknown C++ exception in thread "timerQueue" at Mon Nov 21
2005 12:09:16.378008000
Segmentation fault (core dumped)
[root@dragon iocamd64]#
[root@dragon iocamd64]# gdb ../../bin/linux-x86_64/amd64 core.21331
GNU gdb Red Hat Linux (6.3.0.0-1.63rh)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for
details.
This GDB was configured as "x86_64-redhat-linux-gnu"...Using host
libthread_db library "/lib64/tls/libthread_db.so.1".
warning: core file may not match specified executable file.
Core was generated by `../../bin/linux-x86_64/amd64 ./st.cmd'.
Program terminated with signal 11, Segmentation fault.
(gdb) bt
#0 0x0000003892ab0faa in __gnu_cxx::__verbose_terminate_handler ()
from /usr/lib64/libstdc++.so.6
#1 0x0000003892aaf076 in __cxa_call_unexpected ()
#2 0x0000003892aaf0a3 in std::terminate () from /usr/lib64/libstdc+
+.so.6
#3 0x0000003892aaf0b6 in std::terminate () from /usr/lib64/libstdc+
+.so.6
#4 0x0000003892aaf0d3 in std::unexpected () from /usr/lib64/libstdc+
+.so.6
#5 0x0000002a964b4663 in epicsThreadCallEntryPoint (pPvt=Variable
"pPvt" is not available.
) at ../../../src/libCom/osi/epicsThread.cpp:96
#6 0x0000002a964b9457 in start_routine (arg=Variable "arg" is not
available.
) at ../../../src/libCom/osi/os/posix/osdThread.c:320
#7 0x00000038908060aa in start_thread ()
from /lib64/tls/libpthread.so.0
#8 0x000000388fbc5b43 in clone () from /lib64/tls/libc.so.6
#9 0x0000000000000000 in ?? ()
Ernest
> Marty
> Ernest L. Williams Jr. wrote:
> >Hi,
> >Another issue, when running the example softIOC under linux-x86_64
> >with:
> >USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
> >The following happens only when run as root and only when exit or
> ><CTRL>-C is used to exit the softIOC:
> >cd /ade/epics/iocTop/R3.14.8/testLinux64/iocBoot/iocamd64
> >iocInit()
> >Starting iocInit
> >### EPICS IOC CORE built on Nov 17 2005
> >### EPICS R3.14.7 $$Name: R3-14-2_branch $$ $$Date: 2004/12/06 22:31:52
> >iocInit: All initialization complete
> >## Start any sequence programs
> >#seq sncExample,"user=williamsHost"
> >epics> exit
> >epicsThread: Unknown C++ exception in thread "timerQueue" at Thu Nov 17
> >2005 21:37:19.751377000
> >Let's see what the backtrace yields:
> >(gdb) bt
> >++.so.6
> >++.so.6
> >++.so.6
> >#6 0x0000002a964b9410 in start_routine (arg=Variable "arg" is not
> >available.
> >) at ../../../src/libCom/osi/os/posix/osdThread.c:316
> >(gdb)
> >Thanks,
> >Ernest
- linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Ernest L. Williams Jr.
- Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Marty Kraimer
3.14.8@HP-UX: go! Ralph Lange
Re: epicsThreadSetPriority called by non epics thread Ernest L. Williams Jr.
<2005>
Re: R3.14.8 Status/logClient patch Benjamin Franksen
<2005>
