On Mon, 2005-11-21 at 08:29 -0600, Marty Kraimer wrote:
> Andrew,
> Thanks for finding the missing isEpicsThread.
> I fixed the memory leak.
> I added two new fields to epicsThreadOSD
> isFifoScheduled
> isOnThreadList
> isOnThreadList is set when the thread is added to the list. Thus
> ellDelete is only called if this is true
> isFifoScheduled is used by epicsThreadSetPriority. If not true
> epicsThreadSetPriority. silenly does not try to call posix routines to
> set the priority. I do not know if this is necessary but it may be on
> some posix implementations.
> I have no way to test on my linux because it is old and does not seem to
> support priority scheduling.
> I will get Shifu to test on his linux systems which do.
> Jeff and Earnest,
> Can you try again?
Sure. Tests look good on the 32-bit linux machine for Fedora Core 3 and
4. I am also able to exit the IOC cleanly.
[root@lion iocamd64]# cat /proc/version
Linux version 2.6.12-1.1381_FC3 ([email protected]) (gcc
version 3.4.4 20050721 (Red Hat 3.4.4-2)) #1 Fri Oct 21 03:46:55 EDT
iocInit()
Starting iocInit
### EPICS IOC CORE built on Nov 21 2005
### EPICS R3.14.7 $$Name: R3-14-2_branch $$ $$Date: 2004/12/06 22:31:52
iocInit: All initialization complete
## Start any sequence programs
#seq sncExample,"user=williamsHost"
epics> epicsThreadShowAll
NAME EPICS ID PTHREAD ID OSIPRI OSSPRI STATE
_main_ 0x9360128 0 0 0 OK
errlog 0x9363658 3086908336 10 10 OK
taskwd 0x9368f40 3086744496 10 10 OK
timerQueue 0x9368b00 3086609328 70 69 OK
cbLow 0x9366f18 3086343088 59 58 OK
cbMedium 0x93670a8 3085814704 64 63 OK
cbHigh 0x93a7300 3085286320 71 70 OK
dbCaLink 0x93a7708 3084757936 50 50 OK
scanOnce 0x93ac108 3084229552 70 69 OK
scan10 0x93ac538 3083701168 60 59 OK
scan5 0x93ac660 3083172784 61 60 OK
scan2 0x93ac788 3082644400 62 61 OK
scan1 0x93ac8b0 3082116016 63 62 OK
scan0.5 0x93ac9d8 3081587632 64 63 OK
scan0.2 0x93acb00 3081059248 65 64 OK
scan0.1 0x93acc28 3080530864 66 65 OK
CAC-event 0x93c82e0 3080002480 52 51 OK
CAS-TCP 0x93ceee0 3079736240 16 16 OK
CAS-beacon 0x93cf018 3079470000 14 14 OK
CAS-UDP 0x93cf160 3079334832 12 12 OK
epics> dbl
williamsHost:aiExample
williamsHost:aiExample1
williamsHost:aiExample2
williamsHost:aiExample3
williamsHost:calcExample
williamsHost:calcExample1
williamsHost:calcExample2
williamsHost:calcExample3
williamsHost:compressExample
williamsHost:subExample
williamsHost:xxxExample
epics> casr(2)
Channel Access Server V4.11
Connected circuits:
TCP 160.91.232.168:53705(lion): User="williams", V4.11, 1 Channels,
Priority=50
Task Id=0x93f17d0, Socket FD=3
Secs since last send 0.71, Secs since last receive 10.17
Unprocessed request bytes=0, Undelivered response bytes=0
State=up
416 bytes allocated
williamsHost:aiExample(1rw)
UDP Server:
UDP 160.91.232.168:32784(): User="", V4.11, 0 Channels, Priority=0
Task Id=0x93cf160, Socket FD=7
Secs since last send 10.17, Secs since last receive 10.17
Unprocessed request bytes=16, Undelivered response bytes=0
State=up
168 bytes allocated
There are currently 293748 bytes on the server's free list
6 client(s), 511 channel(s), 511 event(s) (monitors) 0 putNotify(s)
14 small buffers (16384 bytes ea), and 0 jumbo buffers (4000024 bytes
ea)
The server's resource id conversion table:
Bucket entries in use = 1 bytes in use = 16420
Bucket entries/hash id - mean = 0.000244 std dev = 0.015623 max = 1
The server's array size limit is 4000024 bytes max
Channel Access Address List
localhost.localdomain:5065
epics>
Ernest
> Marty
> Andrew Johnson wrote:
> > Jeff Hill wrote:
> >> One has to configure the build setting
> >> "USE_POSIX_THREAD_PRIORITY_SCHEDULING
> >> = YES" on Linux in order to see these messages occurring whenever a
> >> client
> >> connects.
> > Interesting - with that setting I can replicate this on our
> > 2-processor linux server (saturn) but not on my 1-processor linux
> > workstation (apsajnt). I noticed that Jeff was running on an SMP
> > kernel, and I assume his machine has more than one CPU:
> >> Linux version 2.4.21-20.ELsmp ([email protected]) (gcc
> >> version 3.2.3 20030502 (Red Hat Linux 3.2.3-42)) #1 SMP Wed Aug 18
> >> 20:46:40
> >> EDT 2004
> > My boxes look like this:
> > saturn% cat /proc/version
> > Linux version 2.4.20-28.8smp ([email protected]) (gcc
> > version 3.2 20020903 (Red Hat Linux 8.0 3.2-7)) #1 SMP Thu Dec 18
> > 12:25:21 EST 2003
> > apsajnt% cat /proc/version
> > Linux version 2.4.20-19.9 ([email protected]) (gcc
> > version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)) #1 Tue Jul 15 17:18:13
> > EDT 2003
> > Looking at the code in libCom/osi/os/posix/osdThread.c I can now see
> > the problem and explain why it's only happening on SMP systems.
> > This code is from epicsThreadCreate():
> > pthreadInfo = init_threadInfo(name,priority,stackSize,funptr,parm);
> > if(pthreadInfo==0) return 0;
> > pthreadInfo->isEpicsThread = 1;
> > setSchedulingPolicy(pthreadInfo,SCHED_FIFO);
> > status = pthread_create(&pthreadInfo->tid,&pthreadInfo->attr,
> > start_routine,pthreadInfo);
> > if(status==EPERM){
> > parm);
> > The code creates a threadInfo object and calls setSchedulingPolicy().
> > If the subsequent pthread_create() call fails with an EPERM, it tries
> > again without the setSchedulingPolicy(). There are two problems with
> > this: a memory leak, since it never frees the original threadInfo
> > object, and it doesn't set the isEpicsThread flag on the retry. My
> > conjecture is that on an SMP linux kernel pthread_create() does
> > actually return EPERM if the user isn't root, whereas on my single
> > processor (UP) kernel it just accepts (and probably ignores) the
> > thread priority request without error. I have tried running the IOC
> > as root on my workstation, and epicsThreadShowAll lists all the
> > threads with a zero for OSSPRI so it seems that the UP kernel
> > completely ignores the thread priority. Unfortunately I don't have the
> > ability to run the IOC as root on the SMP system, so I can't confirm
> > my guess that way.
> > I have committed a fix to the second problem (forgetting to set the
> > isEpicsThread flag) which removes the messages Jeff was seeing, but
> > the memory leak is harder to fix since the free_threadInfo() routine
> > tries to remove the threadInfo object from a list which it hasn't been
> > added to yet. From the CVS history I see that Marty has already
> > reworked this section of code a bit; I'm going to leave it for him to
> > decide how to fix (there's a FIXME: comment at the relevent line).
> > - Andrew
- RE: epicsThreadSetPriority called by non epics thread Jeff Hill
- Re: epicsThreadSetPriority called by non epics thread Andrew Johnson
- Re: epicsThreadSetPriority called by non epics thread Marty Kraimer
Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Ernest L. Williams Jr.
3.14.8@HP: Known Problem Ralph Lange
<2005>
multiple error messages Benjamin Franksen
<2005>
