2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Link arrays / syntax
To: Steve Lewis <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 19 Oct 2005 11:50:58 -0500
Steve Lewis wrote:
At 7:44 AM -0500 2005/10/19, Marty Kraimer wrote:
Thus we can define
block - wait until all previous record processing activity has completed
process - request the linked record be processed
wait - do not complete this link until the linked record has completed processing.
I like that; think of
  block  => a pre-condition
  process => an attribute of the link
  wait => a post-condition
Also, whatever scheme is chosen, it should map nicely into a visual representation in VDCT.
Could we called the "linked to" record the "target" record?
I don't think viewing "block" as a precondition to link processing
captures enough of its capability, because it misses the code between
link invocations.  This is most clear for input links:
     read something (process target first; notify me on completion)
     do some calculation using the data we will eventually have read
     write something (block for outstanding callbacks before writing)
Block occurs too late to save the calculation from stale data, but
it would have been useful attached to the read link.  If block is
implemented as a precondition, I would expect the following almost
immediately:
 --> link to nothing (block before not linking to anything)
     do some calculation using the data we've now received
     write something ...
I think attaching "block" to links is just expedient; it doesn't
fit perfectly, but putting it there gets a useful capability into
*all* record types.
I just wonder how an end user is going to specify that a link
should wait or block.  Right now, I have a custom seq record that
allows the user to specify wait/nowait for each output link, but
of course this requires an extra field associated with each link.
Tim Mooney ([email protected]) (630)963-1860
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: Link arrays / syntax Andrew Johnson
[Fwd: Re: Link arrays / syntax] Marty Kraimer
Re: [Fwd: Re: Link arrays / syntax] Benjamin Franksen
Re: [Fwd: Re: Link arrays / syntax] Marty Kraimer
Re: Link arrays / syntax Ralph Lange
Re: Link arrays / syntax Marty Kraimer
Re: Link arrays / syntax Steve Lewis
Prev: Re: Link arrays / syntax Steve Lewis
Next: Re: Link arrays / syntax Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
