2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Link arrays / syntax
To: Tim Mooney <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 19 Oct 2005 17:46:46 -0500
Tim Mooney wrote:
I just wonder how an end user is going to specify that a link
should wait or block.  Right now, I have a custom seq record that
allows the user to specify wait/nowait for each output link, but
of course this requires an extra field associated with each link.
Tim's last point is IMHO an important one which I personally think might be part of a better solution to this whole issue of sequencing and synchronization of parallel links. Where we want to give users control over the seq/sync of sets of links there needs to be information supplied to configure the seq/sync process, but this information is not usually meaningful where individual links are used.
It really only seems to make sense for this level of control to be provided for the arrays of inputs to the sub and calc records and for the sequence record, and there we might want to provide additional and more complex sequencing between the input and output links. It should become obvious from that particular example that this sequencing and synchronization between links is really nothing to do with the link type at all, so it shouldn't be specified through the link configuration.
- Andrew
English probably arose from Normans trying to pick up Saxon girls.
Re: Link arrays / syntax Marty Kraimer
[Fwd: Re: Link arrays / syntax] Marty Kraimer
Re: [Fwd: Re: Link arrays / syntax] Benjamin Franksen
Re: [Fwd: Re: Link arrays / syntax] Marty Kraimer
Re: Link arrays / syntax Ralph Lange
Re: Link arrays / syntax Steve Lewis
Re: Link arrays / syntax Tim Mooney
Prev: Re: Link arrays / syntax Tim Mooney
Next: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement) Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Link arrays / syntax Marty Kraimer
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
