Marty Kraimer wrote:
Before
starting on benjamin's message in details I do like "asyn" instead of
"wait".
But perhaps callback is even better with callback=true meaning that
link support will call a callback when the link completes. Either asyn
or callback is better than wait.
I don't like "callback" or "asyn" at all as they are clearly pointing
to implementations of a mechanism.
The database designer should configure what should be
happening, not how it is achieved.
The
proposal to have just
process - boolean, i.e. should request be made to process record
wait - boolean, i.e. link is not complete until linked record completes
processing
block - boolean, i.e. dont do any more record processing until link
completes
Could be implemented easily as follows:
When link support returns it specifies 1) If wait is true, i.e. it will
call a callback when the link completes and
2) If block is true. If wait is true Record support incremements a
counter indicating how many callbacks are outstanding. If block is
true, record support will not do any more record processing until all
outstanding callbacks complete.
This is simple and efficient. Is it intuitive for the Application
Developer?
With regards to the example of the array of processLink, I say yes.
The application developer has control of the order. If the definition
is:
processLink = [3] {
{pvname = "incA"; wait=true},
{pvname = "incB"; wait=true,block=true},
{pvname = "getSample"; wait=true;}
The link for getSample will not be requested until both incA and incB
complete. I think this is intuitive.
There is a problem for separate link fields rather than an array of
links.
Now the order in which the fields appear in the record matter. The
order can never be changed or databases will break.
I still hold up my already expressed concerns:
- The configuration has different lines for "incA" and "incB",
while in the course of record execution they are treated the same.
The "block" statement in your example controls something that happens
afterwards, it would logically apply to "incA" in the same fashion.
It is really rather the "getSample" link whose execution is blocked
until all previous records have finished.
I see a good chance of confusion as the designer always has to
remember: Does "block=true" mean that this record is blocked or that
the next record is blocked?
- What happens if I set a link "wait=false, block=true"?
- Why doesn't the "getSample" have a "block=true" definition? Isn't
further processing of the record held up until the processing is
finished? Is "block=true" inherent for the last link in the array? Even
if it is set "wait=false"?
I guess what you really want to do is define a group of records
that are waited for. The "block" directive is just a way of getting
around a real group definition syntax. With side effects.
In a different view: It looks like your "block=true" really defines
something like a checkpoint ("proceed after all outstanding
procs have finished") after the link it is attached to. Is there a way
to declare such checkpoints within the array, but separate from the
links?
Seems like the "block" directive introduces some dangerous mixture of
data (link info) and control (group info, checkpoints). Should these
things be rather separated?
Ralph
- Re: Link arrays / syntax Marty Kraimer
- [Fwd: Re: Link arrays / syntax] Marty Kraimer
- Re: [Fwd: Re: Link arrays / syntax] Benjamin Franksen
- Re: [Fwd: Re: Link arrays / syntax] Marty Kraimer
RE: FW: Ice GPL based Licensing Jeff Hill
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
