1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: dbGetLink question
Date: Fri, 1 Dec 2017 14:47:22 +0000
Folks,
I have a question about how dbGetLink works.  I have read the Application Developer's Guide (3.15.5) but it is not clear.  Specifically I want to understand how it works under the following conditions:
- Link is an output link
- Link process type is CA
- The output PV resides in another IOC.
Does dbGetLink actually read the value from the other IOC?  It seems like that would be a slow operation, and so would require the record to be asynchronous?  Or does the database put a camonitor on that external record so the link value can be obtained without an actual caget operation?  If so, I cannot find this mentioned in the Application Developer's Guide.  It only describes channel access monitors being set up for input links, not output links.
Re: dbGetLink question Andrew Johnson
Prev: RE: Channel access blocking Mark Engbretson
Next: Re: Channel access blocking Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Channel access blocking Williams Jr., Ernest L.
Next: Re: dbGetLink question Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
