1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Channel access blocking
To: "'Hidas, Dean'" <[email protected]>, <[email protected]>
Date: Fri, 1 Dec 2017 08:42:35 -0600
You could use
EPICS_CA_ADDR_LIST
And set it to the broadcast address(s) of the interface(s) that you want to
use and set
EPICS_CA_AUTO_ADDR_LIST=NO
So that EPICS will not try to use ever Ethernet adapter that it detects.
-----Original Message-----
On Behalf Of Hidas, Dean
Sent: Friday, December 1, 2017 7:27 AM
To: [email protected]
Subject: Channel access blocking
I'm using EPICS R3.14.12.3-8.  I have a (many) PC with 2 ethernet ports
connected to different networks.  Is there a simple way to completely block
channel access from 1 of them? ie, make all PVs, beacons, etc unavailable to
that interface?
Thanks for your help,
-Dean Hidas=
Re: Channel access blocking Mark Rivers
Channel access blocking Hidas, Dean
Prev: Re: EPID bumpless restart Mark Rivers
Next: dbGetLink question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Channel access blocking Hidas, Dean
Next: Re: Channel access blocking Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
