In the display builder, the XYPlot is meant for X and Y waveforms.
If you have one or more scalar PVs for Y that you want to plot over time, use the Data Browser widget.
-Kay
Hi:
I am using X/YPlot widget in Display Builder.X Axis represents time without PV.Y Axis has its pv which means only Y data will be plotted. But it can not update the trace . But when I use XY Graph widget in OPI ,Update Mode property of the trace is set to
Trigger . A trigger_pv and y_pv are set ,then it will update the trace.How I can use X/YPlot in Display Builder?
Thank you for your time.
Xus
- XYPlot in Display Builder xus
iocxxxInclude.dbd Sobhani, Bayan
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
