I am using X/YPlot widget in Display Builder.X Axis represents time without PV.Y Axis has its pv which means only Y data will be plotted. But it can not update the trace . But when I use XY Graph widget in OPI ,Update Mode property of the trace is set to Trigger . A trigger_pv and y_pv are set ,then it will update the trace.How I can use X/YPlot in Display Builder? Thank you for your time. Xus
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
