Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: Problems getting PI motors working
To: 'Eric Norum' <eric@norum.ca>
Cc: EPICS mailing list <tech-talk@aps.anl.gov>
Date: Tue, 24 Oct 2017 19:50:39 +0000
You are definitely not the first person to make this mistake, which I why I recognized it right away.  We should probably print a better error message from devMotorAsyn than just reporting that the int32 interface is not found, providing more of a hint as to what is probably wrong.
Sent: Tuesday, October 24, 2017 2:34 PM
To: Mark Rivers
Subject: Re: Problems getting PI motors working
Is my face ever red.
Yes, I had the wrong ASYN port name in the database.  I was referring to the TCP port not the motor port.
All working now.   Sorry for the interruption!
On Oct 24, 2017, at 10:52 AM, Mark Rivers <rivers@cars.uchicago.edu> wrote:
That error about the int32 interface not being found is familiar.  It is usually a problem with the database file, where the wrong asyn port name is used in the motor record INP link.  It should be the port for the asynMotorController driver, i.e. PIE873_1 or PIE873_1 in your case.  But perhaps instead you have used the name of the underlying TCP port, i.e. pie873A or pie873B in your case?
Eric Norum
eric@norum.ca
Problems getting PI motors working Eric Norum
RE: Problems getting PI motors working Mark Rivers
Re: Problems getting PI motors working Eric Norum
Prev: Re: Problems getting PI motors working Eric Norum
Next: Re: Online EPICS training Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: standard motion connections and pinouts Ernesto Paiser
ANJ, 24 Oct 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
