Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Problems getting PI motors working
To: Mark Rivers <rivers@cars.uchicago.edu>, EPICS mailing list <tech-talk@aps.anl.gov>
Date: Tue, 24 Oct 2017 10:47:44 -0700
I have to admit that I find the EPICS motor record and associated drivers pretty much a black art.  I’m trying to get some PI motors running but I’m getting error messages and subsequent core dumps.  Below is the IOC startup and application Makefile.  The PI_GCS2_CreateController call seems to work fine, but then at record initialization time I get a report that the int32 interface can’t be found and then later on I get a core dump when some NULL pointers get dereferenced.   I suspect that I’m missing some ‘.dbd’ file in my application Makefile, but I don’t know how to figure out what.
Suggestions eagerly welcomed.
#!../../bin/linux-x86_64/piMotor
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocpiMotor")
epicsEnvSet("TOP","/home/als1/acct/enorum/tmp/piMotor")
epicsEnvSet("ASYN","/usr/local/epics/R3.14.12/modules/R3/soft/synApps_5_8/support/asyn4-28")
epicsEnvSet("MOTOR","/usr/local/epics/R3.14.12/modules/R3/soft/motor/motorR6-9")
epicsEnvSet("EPICS_BASE","/usr/local/epics/R3.14.12/base")
epicsEnvSet("IOC_INFO","/iocinfo")
cd "/home/als1/acct/enorum/tmp/piMotor"
dbLoadDatabase "dbd/piMotor.dbd"
piMotor_registerRecordDeviceDriver pdbbase
# PI piezzo motors
drvAsynIPPortConfigure("pie873A","131.243.201.111:50000", 0, 0, 0)
asynOctetSetInputEos("pie873A",0,"\n")
asynOctetSetOutputEos("pie873A",0,"\n")
asynSetTraceMask("pie873A", 0, 1)
asynSetTraceIOMask("pie873A", 0, 1)
# PI_GCS2_CreateController(
#  port name,
#  asyn port name,
#  num axes,
#  priority,
#  stackSize,
#  moving poll period (ms),
#  idle poll period (ms) )
PI_GCS2_CreateController("PIE873_1", "pie873A", 1, 0, 0, 200, 1000)
2017/10/24 10:41:44.931 read from pie873A: (c)2016 Physik Instrumente (PI) GmbH & Co. KG, E-873.1A1, 117011563, 02.012
PIasynAxis::PIasynAxis() 0: 1
drvAsynIPPortConfigure("pie873B","131.243.201.112:50000", 0, 0, 0)
asynOctetSetInputEos("pie873B",0,"\n")
asynOctetSetOutputEos("pie873B",0,"\n")
asynSetTraceMask("pie873B", 0, 1)
asynSetTraceIOMask("pie873B", 0, 1)
#  port name,
#  asyn port name,
#  num axes,
#  priority,
#  stackSize,
PI_GCS2_CreateController("PIE873_2", "pie873B", 1, 0, 0, 200, 1000)
2017/10/24 10:41:45.029 read from pie873B: (c)2016 Physik Instrumente (PI) GmbH & Co. KG, E-873.1A1, 117011567, 02.012
dbLoadRecords("db/PI_motor.db")
# Start EPICS
cd /home/als1/acct/enorum/tmp/piMotor/iocBoot/iocpiMotor
iocInit
Starting iocInit
## EPICS R3.14.12.1 $Date: Tue 2011-04-26 15:36:19 -0500$
## EPICS Base built Sep  3 2013
2017/10/24 10:41:45.110 devMotorAsyn::init_record, PIE873:m1 find int32 interface failed
2017/10/24 10:41:45.110 devMotorAsyn::init_record, PIE873:m2 find int32 interface failed
Segmentation fault (core dumped)
And here’s my application Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC application
PROD_IOC = piMotor
# piMotor.dbd will be created and installed
DBD += piMotor.dbd
# piMotor.dbd will be made up from these files:
piMotor_DBD += base.dbd
# Include dbd files from all support applications:
piMotor_DBD += asyn.dbd
piMotor_DBD += drvAsynIPPort.dbd
piMotor_DBD += motorSupport.dbd
piMotor_DBD += motorSimSupport.dbd
piMotor_DBD += PI_GCS2Support.dbd
# Add all the support libraries needed by this IOC
piMotor_LIBS += asyn
piMotor_LIBS += motor
piMotor_LIBS += motorSimSupport
piMotor_LIBS += PI_GCS2Support
# piMotor_registerRecordDeviceDriver.cpp derives from piMotor.dbd
piMotor_SRCS += piMotor_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
piMotor_SRCS_DEFAULT += piMotorMain.cpp
piMotor_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#piMotor_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Finally link to the EPICS Base libraries
piMotor_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
Eric Norum
eric@norum.ca
RE: Problems getting PI motors working Mark Rivers
Prev: Re: Epics Motor Record Encoder Sense Stubbs, Scott A.
Next: RE: Problems getting PI motors working Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Building example IOC app on Windows Flewellen-Gore, Andrew (US)
ANJ, 24 Oct 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
