1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Display of waveform data in CSS
To: Iain Marcuson <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 23 Oct 2017 18:24:34 +0000
>  I didn't realize you had to drag the desired display widget into the Array widget.
Right, you need to add one 'prototype' widget that's then used to handle each array element.
Use a 'Text Update' for a read-only display, or a 'Text Entry' or some slider widget to edit the array elements.
The example actually shows a more complicated case where the array element is represented by a Group of slider (to write) and text update (to show the number).
It's probably a bad idea to go overboard in that direction, best to just have one plain widget per array element.
-Kay
Display of waveform data in CSS Iain Marcuson
Re: Display of waveform data in CSS Kasemir, Kay
RE: Display of waveform data in CSS Iain Marcuson
Prev: RE: Display of waveform data in CSS Iain Marcuson
Next: Building example IOC app on Windows Flewellen-Gore, Andrew (US)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
