Hi Wolfgang,
You could also use the command EDI that inverts encoder direction on
OMS Pro-dex MAXnet.
MAXnet Command Reference Manual (Rev G), page 105, section 2-97)
Best regards,
Žiga
On 23.10.2017 8:23, Mark Rivers wrote:
I'm not sure, but I think you may need to do this in hardware, i.e. swap either the motor phases or the encoder phases.
From: [email protected] [mailto:[email protected]] On Behalf Of Mexner, Wolfgang (IBPT)
Sent: Monday, October 23, 2017 10:15 AM
To: [email protected]
Subject: Epics Motor Record Encoder Sense
Hallo,
I am new in epics motor record control and try to configure my first axis with encoder. I am now in trouble with an linear axis with encoder Pro (dex Maxnet Controller). Without encoder. the axis works fine. I activated encoder read out by adding PSE to the init string, UEIP to yes and ERES to 5e-5, then the RBV field changes negative by the correct absolute value, when I move positive with TWF .1. I tried to set ERES negative to -5e-5 without any effect. Has somebody an idea how to change the sense of the encoder readout?
Thank you very much
Wolfgang
- Re: Epics Motor Record Encoder Sense Stubbs, Scott A.
- Epics Motor Record Encoder Sense Mexner, Wolfgang (IBPT)
- RE: Epics Motor Record Encoder Sense Mark Rivers
Re: Epics Motor Record Encoder Sense Pearson, Matthew R.
Display of waveform data in CSS Iain Marcuson
<2017>
<2017>
