1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics Motor Record Encoder Sense
To: "Mexner, Wolfgang (IBPT)" <[email protected]>
Cc: "[email protected] list" <[email protected]>
Date: Mon, 23 Oct 2017 16:07:03 +0000
Hi Wolfgang,
Setting ERES negative should work, and I do that on some systems. Although where possible I try to avoid it so that the motor and encoder steps move in the same direction on the controller hardware.
What do the raw count values do? These are available in the RMP and REP fields. ERES is just used to convert REP into engineering units, and put it into RBV (if UEIP=1). So if REP is negative, the negative ERES should result in a positive RBV value.
I’m not familiar with that controller, but some controllers have a way to invert the encoder pulse direction.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
> On Oct 23, 2017, at 11:15 AM, Mexner, Wolfgang (IBPT) <[email protected]> wrote:
> Hallo,
> I am new in epics motor record control and try to configure my first axis with encoder. I am now in trouble with an linear axis with encoder Pro (dex Maxnet Controller). Without encoder. the axis works fine. I activated encoder read out by adding PSE to the init string, UEIP to yes and ERES to 5e-5, then the RBV field changes negative by the correct absolute value, when I move positive with TWF .1. I tried to set ERES negative to -5e-5 without any effect. Has somebody an idea how to change the sense of the encoder readout?
> Thank you very much
>    Wolfgang
Epics Motor Record Encoder Sense Mexner, Wolfgang (IBPT)
Prev: RE: Epics Motor Record Encoder Sense Mark Rivers
Next: Re: Epics Motor Record Encoder Sense Žiga Oven
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Epics Motor Record Encoder Sense Stubbs, Scott A.
Next: Display of waveform data in CSS Iain Marcuson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
