Hello, I am currently using EPICS Base 3.14.12.6 with a linux x86_64 machine and am a relatively new user to EPICS. I want to run an EPICS Application as a Linux target instead of a VxWorks target and was told that the method to do so was to edit the "App/src/" directory's Makefile but not sure as to how to approach that task. How does a user add the support libraries needed for certain C code subroutines from their usr/include path? For example, I need to add the "types.h" header file. I notice there are flag statements (+=) in the makefile as follows: # Build the main IOC entry point where needed example_SRCS_DEFAULT += exampleMain.cpp example_SRCS_vxWorks += -nil- # Link in the code from our support library example_LIBS += exampleSupport I suspect that if I can add the necessary support libraries, then my EPICS app and database will function correctly. Thanks for the help, Nab Rahman
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
