1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Question about epics/Labview and Ca Lab -- how to put time to my PV from signal waveform chart in labview.
To: <[email protected]>
Date: Wed, 27 Sep 2017 12:07:49 +0200
Hello Zhefu,
your EPICS PV "caLab:waveDouble" already has a "native" EPICS time stamp. It will be automatically generated. You can see it when you set up a camonitor session. If this time stamp is unacceptable then you can write any time stamp to a second EPICS PV at same time (CA Lab can take a array of PV names to write to; see examples at homepage). But remember it won't be a consistent data set because of delay difference of data transmissions.
Best regards
Carsten
Example solution:
Am 26.09.2017 um 15:27 schrieb lzf neu:
hi,
I want to put the signal waveform chart versus time to my PV from labview, and camonitor the PV in epics terminal.
I install Calab software to do this. As can be seen from the test.vi file in the attatchment. I could put waveform values (values of Y axis of chart by using NI-Scope widget) to my epics PV ("caLab:waveDouble") by using "Ca Lab epics put " widget.
My problem is that I have no idea how to put time (values of X axis of chart) to another PV by using
"Ca Lab epics put " widget or any other methods, so I can camonitor the PV in epics terminal.
I have attatched the labview file (test.vi) in the attatchement, any help will be appreciated and thanks in advance.
Zhefu
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Question about epics/Labview and Ca Lab -- how to put time to my PV from signal waveform chart in labview. lzf neu
Prev: issue with epics in python Cyrille Thomas
Next: registerRecordDeviceDriver.pl takes a long time to finish Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Question about epics/Labview and Ca Lab -- how to put time to my PV from signal waveform chart in labview. lzf neu
Next: EPICS base startup directory in an installation location. Jeong Han Lee
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
