Here I put out a new release of PCASpy. The reason for this minor version bump is the incompatible changes:
* Changed :meth:`gdd.get` to return empty string if char(int8/uin8) typed scalar is 0. It used to return ``'\x00'``, this confuses the check for an empty string.
* Changed :meth:`Driver.setParam` so that waveform PV always posts monitor/archive events. It used to check the equality.
Also new features get added,
* Fixed numpy array checking. (Issue #44)
* Added adel/mdel fields in scalar PV configuration in analog to EPICS IOC records. (Issue #46)
* Added :meth:`Driver.getParamInfo` to retrieve the current PV configuration. (PR #45)
* Added an example *rpi_gpio.py* to control GPIO on RaspberryPi.
The binary packages should appear shortly at PyPI and anaconda paulscherrerinstitute channel.
Thanks all for the bug reports and pull requests.
Best
Xiaoqiang
RE: Enumerated Strings in CSS BOY Iain Marcuson
quadEM R9-0 now available Mark Rivers
<2017>
<2017>
