Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: quadEM R9-0 now available
To: tech-talk <tech-talk@aps.anl.gov>
Date: Fri, 22 Sep 2017 14:01:38 +0000
Folks,
quadEM R9-0 is now available.
This is from the R9-0 release notes:
- Fixed a problem with PingPong on the NSLS_EM. If ValuesPerRead>1 then it now forces PingPong=Both.
  Previously if ValuesPerRead was even and PingPong was Phase0 or Phase1 then the driver might not update because the device was only sending the other phase.
  Even if ValuesPerRead was odd the phase information was not correct.
- Finished documentation for NSLS2_EM.
- Changed the quadEM.template file to load NDArrayDriver.template, i.e. the database for the asynNDArrayDriver base class. This ensures that records for the base class are present.
  This change requires changing the startup scripts to pass ADDR=0 and TIMEOUT=1 when loading the device template file, because these macros are required by NDArrayDriver.template.
   Because this is not backwards compatible this is major release.
- Updated quadEMTestAppMain.cpp to the version in the template files in EPICS base 3.15.5. This includes a call to epicsExit() after the iocsh() returns.
  This is needed for epicsAtExit to work correctly on some platforms, including Windows.
This is from the R8-0 release notes:
- Minor changes to be compatible with areaDetector/ADCore R3-0. The quadEM base class constructor has changed its arguments, so this is a major release.
  There are no changes required to startup scripts or OPI displays.
The home page is here:
http://cars.uchicago.edu/software/epics/quadEM.html
The documentation is here:
http://cars.uchicago.edu/software/epics/quadEMDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/quadEMReleaseNotes.html
The software repository is on github.  Releases can be obtained there.
https://github.com/epics-modules/quadEM
Let me know of any problems or suggestions.
Prev: PCASpy 0.7 Wang Xiaoqiang (PSI)
Next: measComp R1-4 released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 22 Sep 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
