Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Modbus R2-10-1 available
To: Mark Rivers <rivers@cars.uchicago.edu>, epics Techtalk <tech-talk@aps.anl.gov>
Date: Fri, 15 Sep 2017 20:44:03 +0000
Folks,
Just after releasing R2-10 this morning I realized there was an important outstanding pull request.  I have merged it and done some testing, so I am now releasing 2-10-1.
This is the new item from the release notes:
- Previously the Modbus/TCP transaction ID was set to 1 on writes and ignored on reads.
  Now the Modbus transaction ID is incremented by 1 on each message sent by the driver.
  On the reply the driver waits until a message with the correct transaction ID is received, ignoring messages with any other transaction ID.
  This is more robust, especially for Modbus/UDP links. Thanks to Eric Norum for this.
This change assumes that the Modbus server correctly implements the Modbus/TCP specification which requires it to echo back the transaction ID that it receives.  I have tested this on several Modbus servers.  If in the future we find that there are non-compliant Modbus servers then we can add an option to disable the check on the received messages.
The home page is here:
http://cars.uchicago.edu/software/epics/modbus.html
The release notes are here:
http://cars.uchicago.edu/software/epics/modbusReleaseNotes.html
The documentation is here:
http://cars.uchicago.edu/software/epics/modbusDoc.html
The repository is on Github:
https://github.com/epics-modules/modbus
Prev: acctst failure Al Honey
Next: Re: acctst failure Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: acctst failure Andrew Johnson
Next: New versions of ipUnidig, ip330, and dac128V modules have been released Mark Rivers
ANJ, 17 Sep 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
