Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: acctst failure
To: <tech-talk@aps.anl.gov>
Date: Fri, 15 Sep 2017 17:30:58 -0500
Hi Al,
On 09/15/2017 03:40 PM, Al Honey wrote:
> I am running the acctst (r3.14.12.5) on a softIOC (REHLv7).
> acctst timerperiod 2 1 10 1
> where timerperiod is an analog output record with DTYP of Soft Channel
> Everything runs fine up until the caTaskExitTest (see below).
> Any ideas as to why ca_task_exit() would cause a segmentation fault.
I am unable to replicate your failures running R3.14.12.5 on my RHEL-7.4
workstation against a local softIoc.
However the issue might be due to lp:1580623 or lp:1558206 both of which
were fixed in the later 3.14.12.6 release and could cause seg-faults at
program exit in some circumstances. There may have been other fixes that
might have resolved such problems, but those were the main ones I can
see. Can you try this again using R3.14.12.6?
- Andrew
acctst failure Al Honey
Prev: Modbus R2-10-1 available Mark Rivers
Next: New versions of ipUnidig, ip330, and dac128V modules have been released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: acctst failure Al Honey
Next: Modbus R2-10-1 available Mark Rivers
ANJ, 17 Sep 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
