Hello
Thank you! it worked. Now I've got a bin folder and an executable file WithAsyn within it.
Let me ask you then, if I want to connect to a PI controller, do I need to create a st.cmd file that loads the right resources for that purpose?
Because the preinstalled files don't seem to be what i want to run.
Sorry, I'm new to EPICS and am still investigating how can we develop applications for it.
Thanks
Guilherme Jovanini Montagner
+55 19 2517.8911
+55 19 99806.9117
[email protected]
----- Mensagem original -----
De: "Mark Rivers" <[email protected]>
Para: "guilherme" <[email protected]>, "Ronald L. Sluiter" <[email protected]>
Cc: "tech-talk" <[email protected]>
Enviadas: Quarta-feira, 13 de setembro de 2017 9:03:19
Assunto: RE: Help creating motorR6-9 examples
> Can it be because I have another folder with motorR6-8 on the machine?
No, this error is because motor R6-9 is not compatible with base 3.15 or 3.16. PI_GCS2Support.dbd includes the motor record, which it should not do.
You can comment out these 2 lines in PI_GCS2Support.dbd
include "asyn.dbd"
include "motorRecord.dbd"
Or you can get the master branch from github, https://github.com/epics-modules/motor
I know that the master branch works on base 3.15.5, but I see that are working with base 3.16.1 and I am not sure if that has been tested with motor yet.
From: [email protected] [[email protected]] on behalf of Guilherme Jovanini Montagner [[email protected]]
Sent: Wednesday, September 13, 2017 6:51 AM
To: Ronald L. Sluiter
Cc: tech-talk
Subject: Re: Help creating motorR6-9 examples
Hello again, good morning.
I've just tried that, and then, make outputs the following error:
Creating dbd file WithAsyn.dbd
perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/setup/Downloads/support/asyn4-31/dbd -I/home/setup/Downloads/base-3.16.1/dbd -I../../../dbd -o WithAsyn.dbd base.dbd motorSupport.dbd PI_GCS2Support.dbd
dbdExpand.pl: Duplicate definition of record type 'motor'
Context: recordtype(motor) in file '../../../dbd/motorRecord.dbd' in file '../../../dbd/PI_GCS2Support.dbd'
while reading 'PI_GCS2Support.dbd' to create 'WithAsyn.dbd'
dbdExpand.pl: Exiting due to errors
Thanks again.
+55 19 2517.8911
+55 19 99806.9117
[email protected]
De: "Ronald L. Sluiter" <[email protected]>
Para: "tech-talk" <[email protected]>
Enviadas: Terça-feira, 12 de setembro de 2017 18:05:43
Assunto: Fwd: Re: Help creating motorR6-9 examples
-------- Forwarded Message --------
Date: Tue, 12 Sep 2017 15:57:49 -0500
To: Guilherme Jovanini Montagner <[email protected]>
Hello Guilherme,
I see from the makedump.txt file you sent that you are only building the
"MotorSrc" and "PIGCS2Src" directories. That is OK, but the <motor>/motorExApp
assumes that all the support directories are built.
You could follow one of two paths. One path would be to restore
motorR6-9/motorApp/Makefile to its' orginial state and rebuild.
The other, minimalist, path would be to comment out (or remove) from motorExApp
everything irrelavent to PIGCS2Src support. That requires;
- In motorR6-9/motorExApp/Makefile, comment out "DIRS += NoAsyn" (there is no
PIGCS2Src support in NoAsyn).
- Replace motorR6-9/motorExApp/WithAsyn/Makefile with the attached copy.
- rebuild
I think that should work.
Ron
On 09/12/2017 03:25 PM, Guilherme Jovanini Montagner wrote:
> Hi.
> Ok, here it is (attached)
> I'll have to go now, but I'll come back.
> Thanks!
> +55 19 2517.8911
> +55 19 99806.9117
> [email protected]
> Enviadas: Terça-feira, 12 de setembro de 2017 17:17:16
> Assunto: Re: Help creating motorR6-9 examples
> Could you run the following command at the top directory,
>> make >& makedump.txt
> and send me the file.
> Ron
> On 09/12/2017 03:13 PM, Guilherme Jovanini Montagner wrote:
>> Hi again. Yes, I have run make from the top, and after, tried running it again from the child directory.
>> +55 19 2517.8911
>> +55 19 99806.9117
>> [email protected]
>> Para: "guilherme" <[email protected]>, "tech-talk" <[email protected]>
>> Enviadas: Terça-feira, 12 de setembro de 2017 17:06:32
>> If you did not run "make" from the top level "motorR6-9" directory, that could
>> be why you are getting these errors. The EPICS motor module, like EPICS base and
>> most other EPICS modules, assumes that "make" is run 1st from the top level
>> directory. After running 'make' from the top level you can make custom changes
>> and taylor the module to your specific needs, but you should run make from the
>> top 1st.
>> Ron
>> On 09/12/2017 02:57 PM, Ronald L. Sluiter wrote:
>>> Hello Guilherme,
>>> I am guessing that the SoftMotorSrc directory did not get built. If you 'ls'
>>> the SoftMotorSrc directory you should get this;
>>>> % ls motorApp/SoftMotorSrc
>>>> devSoftAux.cc devSoft.cc devSoft.h devSoftMotor.dbd Makefile O.Common
>>>> O.linux-x86_64
>>> and there should be a 'devSoftMotor.dbd' file installed in the top 'dbd'
>>> directory.
>>>> galadriel% ls dbd
>>>> ACRMotorSupport.dbd devDeltaTau.dbd devMclennanMotor.dbd
>>>> devNewport.dbd devPIJena.dbd *devSoftMotor.dbd* MicronixSupport.dbd
>>>> motorSupport.dbd omsAsynSupport.dbd
>>>> devAcsMotor.dbd devFaulhaberMotor.dbd devMicos.dbd devOms.dbd
>>>> devPIMotor.dbd devSPiiPlus.dbd motorRecord.dbd NoAsyn.dbd
>>>> phytron.dbd
>>>> devAerotech.dbd devImsMotor.dbd devMicroMo.dbd devOriel.dbd
>>>> devSmarActMCSMotor.dbd devThorLabs.dbd motorSim.dbd NoAsynVx.dbd
>>>> PI_GCS2Support.dbd
>>>> devAttocube.dbd devKohzuMotor.dbd devNewFocus.dbd
>>>> devPC6K.dbd devSmartMotorMotor.dbd HytecMotorDriver.dbd
>>>> motorSimSupport.dbd NPointMotorSupport.dbd
>>> What do you see in those two directories?
>>> Ron
>>> On 09/12/2017 02:25 PM, Guilherme Jovanini Montagner wrote:
>>>> Hi!
>>>> I'm involved in a Project in which EPICS is to be used, and am currently
>>>> trying to create a working example using a PI piezo controller.
>>>> I want some help doing this.
>>>> I've uncommented the lines
>>>> DIRS += motorExApp iocBoot
>>>> motorExApp_DEPEND_DIRS = motorApp
>>>> iocBoot_DEPEND_DIRS = motorExApp
>>>> from the top makefile. I've also uncommented the line "MOTOR=$(TOP)" in
>>>> configure/RELEASE file
>>>> Also, on the file motorApp/Makefile, I've got the lines
>>>> DIRS +=PIGCS2Src
>>>> PIGCS2Src_DEPEND_DIRS = MotorSrc
>>>> uncommented.
>>>> The problem is, when I run make on top, I get the following message:
>>>> [setup@localhost motorExApp]$ make
>>>> make -C ./NoAsyn install
>>>> make[1]: Entering directory
>>>> `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
>>>> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
>>>> T_A=linux-x86_64 install
>>>> make[2]: Entering directory
>>>> `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
>>>> Creating dbd file NoAsyn.dbd
>>>> -I/home/setup/Downloads/base-3.16.1/dbd -o NoAsyn.dbd base.dbd
>>>> motorRecord.dbd devSoftMotor.dbd Misc.dbd
>>>> dbdExpand.pl: Can't find file 'devSoftMotor.dbd'
>>>> while reading 'devSoftMotor.dbd' to create 'NoAsyn.dbd'
>>>> Your Makefile may need this dependency rule:
>>>> $(COMMON_DIR)/NoAsyn.dbd: $(COMMON_DIR)/devSoftMotor.dbd
>>>> make[2]: *** [../O.Common/NoAsyn.dbd] Error 255
>>>> make[2]: Leaving directory
>>>> make[1]: *** [install.linux-x86_64] Error 2
>>>> make[1]: Leaving directory
>>>> make: *** [NoAsyn.install] Error 2
>>>> Then, I proceeded to add the mentioned line on motorExApp/NoAsyn/Makefile:
>>>> ADD MACRO DEFINITIONS AFTER THIS LINE
>>>> PROD_IOC_DEFAULT = NoAsyn
>>>> PROD_IOC_vxWorks = NoAsynVx
>>>> COMMONDBDS = base.dbd
>>>> COMMONDBDS += motorRecord.dbd
>>>> COMMONDBDS += devSoftMotor.dbd
>>>> #!COMMONDBDS += devMXmotor.dbd
>>>> but when I run make again, after doing that, I get the following error:
>>>> Creating dbd file devSoftMotor.dbd
>>>> -I/home/setup/Downloads/base-3.16.1/dbd -o devSoftMotor.dbd
>>>> dbdExpand.pl: No input files for devSoftMotor.dbd
>>>> make[2]: *** [../O.Common/devSoftMotor.dbd] Error 255
>>>> I don't know where is this devSoftMotor.dbd being called, and why it doesn't
>>>> have input arguments.
>>>> Could you help me, please?
>>>> Thanks,
>>>> Guilherme
>>>> *Guilherme Jovanini Montagner*
>>>> +55 19 2517.8911
>>>> +55 19 99806.9117
>>>> [email protected]
- RE: Help creating motorR6-9 examples Mark Rivers
- Fwd: Re: Help creating motorR6-9 examples Ronald L. Sluiter
- Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
pre-ICALEPCS EPICS workshop reminder Timo Korhonen
<2017>
<2017>
