1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: cannot read ioc PVs with caget
To: "Antal, Szabolcs" <[email protected]>
Date: Fri, 8 Sep 2017 13:22:41 +0200
Ah good.  I suggested the same to the student, but never heard back from him on it (which I assumed it worked, but not really sure about that…).
I was about to setup and check myself, too…
I will make sure to have that listed on the download page for the STAR EPICS VM.
> On Sep 8, 2017, at 1:20 PM, Antal, Szabolcs <[email protected]> wrote:
> I do use your VM :)
> Thank you for the suggestion, and indeed it was the solution to my problem!
> After executing
> 	su root /etc/init.d/iptables stop
> it works like a charm!
> Yours truly,
> ____________________
> Szabolcs Antal
> Software Developer
> evopro systems engineering Kft.
> member of the evopro group
> HU-4031, Debrecen, Köntösgátsor 1-3. Daniella Ipari Park
> www.evopro-group.com
> Mobile: +36 30 310 0367
> -----Original Message-----
> From: Jiro Fujita [mailto:[email protected]]
> Sent: Friday, September 08, 2017 1:01 PM
> To: Antal, Szabolcs <[email protected]>
> Cc: [email protected]
> If you are using my VM, then, the problem may be to do with the firewall.  Check if you have it running.  In principle, caget should work fine, but just a day or two ago, a student came asked me the same question, which might be a firewall issue.
> You can check that with the following (try as root):
> /etc/init.d/iptables status
> If it’s running, then, you can turn it off by changing status to stop.
>> On Sep 8, 2017, at 12:58 PM, Antal, Szabolcs <[email protected]> wrote:
>> Hi all,
>> To start from the beginning. I’m quite new to EPICS, and I’m
>> experimenting with its basics at the moment, by trying to set up a softIoc from scratch.
>> I have an EPICS base of R3.14.12.5 already installed and the host OS is a RedHat linux.
>> My project structure is as follows:
>> myFirstIoc/
>> ├──PowerSupplySimu.db
>> └───st.cmd
>> When I do softIoc st.cmd the ioc is being initialized and is running, at least it seems like.
>> In the softioc shell I can list the records found in the PowerSupplySimu.db file.
>> epics> dbl
>> PowerSupply1:ReadBack
>> PowerSupply1:OutputValue
>> But when I open a terminal and trying to get the value of any of these PVs like:
>> caget PowerSupply1:Readback
>> I get the following response:
>> Channel connect timed out: ’PowerSupply1:Readback’ not found.
>> I was looking for resources on the web but managed to find nothing unfortunately.
>> I guess I’m overlooking something or some setup is missing, or maybe I’m doing it completely wrong.
>> So what else do I need to get Channel Access work for me?
>> Any help would be appreciated!
>> Yours truly,
>> Szabolcs Antal
>> Software Developer
>> <image003.png>
>> Ez az e-mail (ideértve annak bármely mellékletét) bizalmas információkat tartalmaz és jogi védelem alatt áll. Az üzenet kizárólag a címzett(ek)nek szól. Amennyiben Ön nem a küldemény címzettje, úgy a téves kézbesítést kérjük haladéktalanul jelezze e-mailben a feladónak és a teljes küldeményt helyreállíthatatlanul törölje. Amennyiben Ön nem az üzenet címzettje, kérjük ne készítsen másolatot az üzenetről, ne továbbítsa, ne tárja fel és ne tegye hozzáférhetővé azt más személy(ek) számára, továbbá semmilyen célra ne használja fel a bizalmas információt: ezen magatartások bármelyike a levéltitok megsértésének minősül.
>> Information in this e-mail (including any attachment hereto) is confidential and may be legally privileged. It is intended solely for the attention of the addressee(s). If you received this message in error, please immediately notify the sender by return e-mail and irrecoverably delete the whole message. If you received this e-mail in error, please do not copy it, do not forward, disclose or make it available to other person(s), and do not use the confidential information for any purpose: any such action is regarded as a breach of confidence.
cannot read ioc PVs with caget Antal, Szabolcs
Re: cannot read ioc PVs with caget Jiro Fujita
RE: cannot read ioc PVs with caget Antal, Szabolcs
Prev: RE: cannot read ioc PVs with caget Antal, Szabolcs
Next: Nightly builds Amien Crombie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
