Hi Sue,
My apologies, I found that my version of seq 2-2-4 also has a modified version of lemon.c. Here is the difference
Here is the patch:
[epics@gse-marccd2 lemon]$ diff -U3 lemon.c.orig lemon.c
--- lemon.c.orig 2016-11-25 11:50:21.000000000 -0600
+++ lemon.c 2017-08-24 17:37:51.910633792 -0500
@@ -403,6 +403,7 @@
char *tokendest; /* Code to execute to destroy token data */
char *vardest; /* Code for the default non-terminal destructor */
char *filename; /* Name of the input file */
+ char *outputdir; /* Name of the output directory */
char *outname; /* Name of the current output file */
char *tokenprefix; /* A prefix added to token names in the .h file */
int nconflict; /* Number of parsing conflicts */
@@ -1576,6 +1577,7 @@
static int statistics = 0;
static int mhflag = 0;
static int nolinenosflag = 0;
+ static char *outputdir = 0;
static int noResort = 0;
static struct s_options options[] = {
{OPT_FLAG, "b", (char*)&basisflag, "Print only the basis in report."},
@@ -1594,6 +1596,7 @@
{OPT_FLAG, "s", (char*)&statistics,
"Print parser stats to standard output."},
{OPT_FLAG, "x", (char*)&version, "Print the version number."},
+ {OPT_STR, "o", (char*)&outputdir, "Directory for output files (default: same as input)."},
{OPT_FSTR, "T", (char*)handle_T_option, "Specify a template file."},
{OPT_FSTR, "W", 0, "Ignored. (Placeholder for '-W' compiler options.)"},
{OPT_FLAG,0,0,0}
@@ -1614,6 +1617,7 @@
memset(&lem, 0, sizeof(lem));
lem.errorcnt = 0;
+ lem.outputdir = outputdir;
/* Initialize the machine */
Strsafe_init();
@@ -1725,7 +1729,7 @@
/* return 0 on success, 1 on failure. */
- exitcode = ((lem.errorcnt > 0) || (lem.nconflict > 0)) ? 1 : 0;
+ exitcode = (lem.errorcnt > 0);
exit(exitcode);
return (exitcode);
@@ -2963,13 +2967,37 @@
char *name;
char *cp;
+ char *inputname;
+ int outputdirlen;
+ char *outputdir;
+ outputdir = lemp->outputdir;
+ if (!outputdir) {
+ outputdir = "";
+ outputdirlen = lemonStrlen(outputdir);
+ inputname = strrchr(lemp->filename,'/');
+ if (outputdirlen > 0 && inputname) {
+ inputname += 1;
+ } else {
+ inputname = lemp->filename;
+ name = (char*)malloc( outputdirlen + 1 + lemonStrlen(inputname) + lemonStrlen(suffix) + 1);
- name = (char*)malloc( lemonStrlen(lemp->filename) + lemonStrlen(suffix) + 5 );
if( name==0 ){
fprintf(stderr,"Can't allocate space for a filename.\n");
exit(1);
- lemon_strcpy(name,lemp->filename);
+ lemon_strcpy(name,"");
+ if (outputdirlen > 0) {
+ lemon_strcat(name,outputdir);
+ if (outputdir[outputdirlen-1] != '/') {
+ lemon_strcat(name,"/");
+ lemon_strcat(name,inputname);
cp = strrchr(name,'.');
if( cp ) *cp = 0;
lemon_strcat(name,suffix);
When I revert back to lemon.c.orig it fails with the same error you are getting.
I appear to have made that fix on November 25, 2016.
What is strange to me is that I cannot find any e-mail in which this change is discussed, either in my own e-mail or on tech-talk.
Perhaps Ben remembers this fix? In any event it looks like it a known problems page for 2.2.4 needs to be added here?
https://urldefense.proofpoint.com/v2/url?u=http-3A__www-2Dcsr.bessy.de_control_SoftDist_sequencer_Installation.html-23download&d=DwIFAg&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=9jUweGhYkr3dLAaTIgDP3Q&m=PP_ckA1jhPZ-QbiyiQZuk3meUTEgBEmJBF83h7pcC-4&s=kQqap2WrNrxH1uICAxnD-6diVltj6NXv6NqMpCLbheg&e=
-----Original Message-----
Sent: Thursday, August 24, 2017 3:52 PM
To: Mark Rivers; Tech-talk
Subject: Re: Problems building seq 2.2.4 on Linux
Hi Mark,
Thanks for your response. The tech-talk thread I was talking about,
which is related (I think) to my problem is :
https://urldefense.proofpoint.com/v2/url?u=http-3A__www.aps.anl.gov_epics_tech-2Dtalk_2017_msg00087.php&d=DwIFAg&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=9jUweGhYkr3dLAaTIgDP3Q&m=PP_ckA1jhPZ-QbiyiQZuk3meUTEgBEmJBF83h7pcC-4&s=esu9G7qUBr8NwSb7yvi1pBY1ZMzqLTmsHGBeF50rHA8&e= ..
Ben mentions many-core build machines and also GNUmake versions.... I'm
using 'GNU Make 3.81 built for i686-pc-linux-gnu'
But you are right, I am not generating the snl.h file.
Do you know what rule triggers this generation?
Sue
On 08/24/2017 09:22 AM, Mark Rivers wrote:
Hi Sue,
I can't reproduce that problem.
My system:
seq 2.2.4
Redhat 6 (EPICS_HOST_ARCH=linux-x86-rhel6)
gcc 4.4.7-17
base 3.15.5
perl 5.10.1
I believe I have made only the following change to seq 2.2.4. Tthis was to fix a problem on Windows that was not related to the problem you are seeing.
corvette:seq-2-2-4/src/snc>diff -U3 snl.lt.orig snl.lt
--- snl.lt.orig 2017-01-13 08:38:51.976001963 -0600
+++ snl.lt 2017-01-13 08:35:39.777418847 -0600
@@ -829,11 +829,11 @@
}else if( yyact <= YY_MAX_REDUCE ){
yy_reduce(yypParser,yyact-YY_MIN_REDUCE);
}else{
- assert( yyact == YY_ERROR_ACTION );
- yyminorunion.yy0 = yyminor;
#ifdef YYERRORSYMBOL
int yymx;
#endif
+ assert( yyact == YY_ERROR_ACTION );
+ yyminorunion.yy0 = yyminor;
#ifndef NDEBUG
if( yyTraceFILE ){
fprintf(yyTraceFILE,"%sSyntax Error!\n",yyTracePrompt);
When I build seq 2.2.4 with the -sj options it builds fine with only the following output
[epics@gse-marccd2 seq-2-2-4]$ make -sj clean
m[epics@gse-marccd2 seq-2-2-4]$ make -sj
2 parsing conflicts.
Your first error is this:
../snl.re:16:17: error: snl.h: No such file or directory
So for some reason it is not finding snl.h.
From: [email protected] [[email protected]] on behalf of Sue Witherspoon [[email protected]]
Sent: Tuesday, August 22, 2017 2:59 PM
To: Tech-talk
Subject: Problems building seq 2.2.4 on Linux
I am having problems building seq 2.2.4 on linux:
Redhat 6 (linux-x86)
gcc version 4.4.7
Epics 3.15.5
perl v5.10.1
This is the complete output when building.
devl06 [195]: gmake rebuild
gmake -C ./configure clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
rm -rf O.rhel-6-ia32 O.Common
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
gmake -C ./src clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
gmake -C ./pv clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
gmake -C ./common clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
gmake -C ./seq clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
gmake -C ./lemon clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
gmake -C ./snc clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
gmake -C ./test clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
gmake -C ./compiler clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
gmake -C ./validate clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
gmake -C ./unit clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
gmake -C ./examples clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
gmake -C ./cmdButtons clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
gmake -C ./demo clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
gmake -C ./johng clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
gmake -C ./simple clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
gmake -C ./small clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
gmake -C ./pvGetAsync clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
gmake -C ./configure install
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../..
mkdir O.Common
gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../.. \
T_A=rhel-6-ia32 install
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/convertRelease.pl checkRelease
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
gmake -C ./src install
gmake -C ./pv install
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../../..
mkdir O.Common
gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../../.. \
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF pv.d ../pv.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../pv.c
/usr/bin/ar -rc libpv.a pv.o
/usr/bin/ranlib libpv.a
/usr/bin/g++ -o libpv.so.3.15.5 -shared -fPIC -Wl,-hlibpv.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -rdynamic -m32 pv.o -lca -lCom -Wl,-Bdynamic -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/rhel-6-ia32/libpv.so.3.15.5
ln -s libpv.so.3.15.5 ../../../lib/rhel-6-ia32/libpv.so
Installing library ../../../lib/rhel-6-ia32/libpv.a
gmake -C ./common install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
perl -CSD ../seq_release.pl 2.2.4 > ../O.Common/seq_release.h
Installing generated generic include file ../../../include/seq_release.h
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
gmake -C ./seq install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_queue.d ../seq_queue.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_cmd.d ../seq_cmd.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_qry.d ../seq_qry.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_prog.d ../seq_prog.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_mac.d ../seq_mac.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_if.d ../seq_if.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_ca.d ../seq_ca.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_task.d ../seq_task.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF seq_main.d ../seq_main.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_main.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_task.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_ca.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_if.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_mac.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_prog.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_qry.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_cmd.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../seq_queue.c
/usr/bin/ar -rc libseq.a seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o
/usr/bin/ranlib libseq.a
/usr/bin/g++ -o libseq.so.3.15.5 -shared -fPIC -Wl,-hlibseq.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -rdynamic -m32 seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o -lpv -lCom -Wl,-Bdynamic -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/rhel-6-ia32/libseq.so.3.15.5
ln -s libseq.so.3.15.5 ../../../lib/rhel-6-ia32/libseq.so
Installing library ../../../lib/rhel-6-ia32/libseq.a
gmake -C ./lemon install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -MM -MF lemon.d ../lemon.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c ../lemon.c
/usr/bin/g++ -o lemon -Wl,-Bstatic -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -rdynamic -m32 lemon.o -Wl,-Bdynamic -lpthread -lm -lrt -ldl -lgcc
Installing created executable ../../../bin/rhel-6-ia32/lemon
gmake -C ./snc install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
re2c -s -b -o lexer.c ../snl.re
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m lexer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include lexer.o lexer.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m builtin.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include builtin.o ../builtin.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m sym_table.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include sym_table.o ../sym_table.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m gen_tables.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include gen_tables.o ../gen_tables.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m gen_ss_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include gen_ss_code.o ../gen_ss_code.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m gen_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include gen_code.o ../gen_code.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m analysis.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include analysis.o ../analysis.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m var_types.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include var_types.o ../var_types.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m node.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include node.o ../node.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl -m main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include main.o ../main.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -Wall -m32 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include -c lexer.c
../snl.re: In function 'scan':
../snl.re:330: error: 'TOK_SLASH' undeclared (first use in this function)
../snl.re:330: error: (Each undeclared identifier is reported only once
../snl.re:330: error: for each function it appears in.)
../snl.re:331: error: 'TOK_MOD' undeclared (first use in this function)
../snl.re:285: error: 'TOK_NAME' undeclared (first use in this function)
../snl.re:287: error: 'TOK_INTCON' undeclared (first use in this function)
../snl.re:323: error: 'TOK_PERIOD' undeclared (first use in this function)
../snl.re:333: error: 'TOK_GT' undeclared (first use in this function)
../snl.re:332: error: 'TOK_LT' undeclared (first use in this function)
../snl.re:328: error: 'TOK_ADD' undeclared (first use in this function)
../snl.re:327: error: 'TOK_SUB' undeclared (first use in this function)
../snl.re:329: error: 'TOK_ASTERISK' undeclared (first use in this function)
../snl.re:324: error: 'TOK_AMPERSAND' undeclared (first use in this function)
../snl.re:334: error: 'TOK_CARET' undeclared (first use in this function)
../snl.re:335: error: 'TOK_VBAR' undeclared (first use in this function)
../snl.re:318: error: 'TOK_EQUAL' undeclared (first use in this function)
../snl.re:325: error: 'TOK_NOT' undeclared (first use in this function)
../snl.re:313: error: 'TOK_SEMICOLON' undeclared (first use in this function)
../snl.re:314: error: 'TOK_LBRACE' undeclared (first use in this function)
../snl.re:315: error: 'TOK_RBRACE' undeclared (first use in this function)
../snl.re:316: error: 'TOK_COMMA' undeclared (first use in this function)
../snl.re:317: error: 'TOK_COLON' undeclared (first use in this function)
../snl.re:319: error: 'TOK_LPAREN' undeclared (first use in this function)
../snl.re:320: error: 'TOK_RPAREN' undeclared (first use in this function)
../snl.re:321: error: 'TOK_LBRACKET' undeclared (first use in this function)
../snl.re:322: error: 'TOK_RBRACKET' undeclared (first use in this function)
../snl.re:326: error: 'TOK_TILDE' undeclared (first use in this function)
../snl.re:336: error: 'TOK_QUESTION' undeclared (first use in this function)
../snl.re:312: error: 'TOK_NE' undeclared (first use in this function)
../snl.re:311: error: 'TOK_EQ' undeclared (first use in this function)
../snl.re:308: error: 'TOK_OROR' undeclared (first use in this function)
../snl.re:301: error: 'TOK_OREQ' undeclared (first use in this function)
../snl.re:300: error: 'TOK_XOREQ' undeclared (first use in this function)
../snl.re:307: error: 'TOK_ANDAND' undeclared (first use in this function)
../snl.re:299: error: 'TOK_ANDEQ' undeclared (first use in this function)
../snl.re:296: error: 'TOK_MULEQ' undeclared (first use in this function)
../snl.re:306: error: 'TOK_POINTER' undeclared (first use in this function)
../snl.re:305: error: 'TOK_DECR' undeclared (first use in this function)
../snl.re:295: error: 'TOK_SUBEQ' undeclared (first use in this function)
../snl.re:304: error: 'TOK_INCR' undeclared (first use in this function)
../snl.re:294: error: 'TOK_ADDEQ' undeclared (first use in this function)
../snl.re:309: error: 'TOK_LE' undeclared (first use in this function)
../snl.re:303: error: 'TOK_LSHIFT' undeclared (first use in this function)
../snl.re:293: error: 'TOK_LSHEQ' undeclared (first use in this function)
../snl.re:310: error: 'TOK_GE' undeclared (first use in this function)
../snl.re:302: error: 'TOK_RSHIFT' undeclared (first use in this function)
../snl.re:292: error: 'TOK_RSHEQ' undeclared (first use in this function)
../snl.re:290: error: 'TOK_FPCON' undeclared (first use in this function)
../snl.re:270: error: 'TOK_WHILE' undeclared (first use in this function)
../snl.re:269: error: 'TOK_WHEN' undeclared (first use in this function)
../snl.re:268: error: 'TOK_VOID' undeclared (first use in this function)
../snl.re:267: error: 'TOK_UNSIGNED' undeclared (first use in this function)
../snl.re:266: error: 'TOK_UNION' undeclared (first use in this function)
../snl.re:277: error: 'TOK_UINT32T' undeclared (first use in this function)
../snl.re:275: error: 'TOK_UINT16T' undeclared (first use in this function)
../snl.re:273: error: 'TOK_UINT8T' undeclared (first use in this function)
../snl.re:264: error: 'TOK_TO' undeclared (first use in this function)
../snl.re:265: error: 'TOK_TYPENAME' undeclared (first use in this function)
../snl.re:257: error: 'TOK_SS' undeclared (first use in this function)
../snl.re:263: error: 'TOK_SYNC' undeclared (first use in this function)
../snl.re:261: error: 'TOK_SYNCQ' undeclared (first use in this function)
../snl.re:260: error: 'TOK_STRUCT' undeclared (first use in this function)
../snl.re:259: error: 'TOK_STRING' undeclared (first use in this function)
../snl.re:258: error: 'TOK_STATE' undeclared (first use in this function)
../snl.re:256: error: 'TOK_SIZEOF' undeclared (first use in this function)
../snl.re:255: error: 'TOK_SHORT' undeclared (first use in this function)
../snl.re:254: error: 'TOK_RETURN' undeclared (first use in this function)
../snl.re:253: error: 'TOK_PROGRAM' undeclared (first use in this function)
../snl.re:252: error: 'TOK_OPTION' undeclared (first use in this function)
../snl.re:251: error: 'TOK_MONITOR' undeclared (first use in this function)
../snl.re:250: error: 'TOK_LONG' undeclared (first use in this function)
../snl.re:248: error: 'TOK_IF' undeclared (first use in this function)
../snl.re:249: error: 'TOK_INT' undeclared (first use in this function)
../snl.re:272: error: 'TOK_INT8T' undeclared (first use in this function)
../snl.re:276: error: 'TOK_INT32T' undeclared (first use in this function)
../snl.re:274: error: 'TOK_INT16T' undeclared (first use in this function)
../snl.re:246: error: 'TOK_FOR' undeclared (first use in this function)
../snl.re:247: error: 'TOK_FOREIGN' undeclared (first use in this function)
../snl.re:245: error: 'TOK_FLOAT' undeclared (first use in this function)
../snl.re:244: error: 'TOK_EXIT' undeclared (first use in this function)
../snl.re:243: error: 'TOK_EVFLAG' undeclared (first use in this function)
../snl.re:242: error: 'TOK_ENUM' undeclared (first use in this function)
../snl.re:241: error: 'TOK_ENTRY' undeclared (first use in this function)
../snl.re:240: error: 'TOK_ELSE' undeclared (first use in this function)
../snl.re:239: error: 'TOK_DOUBLE' undeclared (first use in this function)
../snl.re:238: error: 'TOK_CONTINUE' undeclared (first use in this function)
../snl.re:237: error: 'TOK_CONST' undeclared (first use in this function)
../snl.re:236: error: 'TOK_CHAR' undeclared (first use in this function)
../snl.re:235: error: 'TOK_BREAK' undeclared (first use in this function)
../snl.re:234: error: 'TOK_ASSIGN' undeclared (first use in this function)
../snl.re:298: error: 'TOK_MODEQ' undeclared (first use in this function)
../snl.re:297: error: 'TOK_DIVEQ' undeclared (first use in this function)
../snl.re:358: error: 'TOK_STRCON' undeclared (first use in this function)
../snl.re:427: error: 'TOK_CCODE' undeclared (first use in this function)
gmake[3]: *** [lexer.o] Error 1
gmake[2]: *** [install.rhel-6-ia32] Error 2
gmake[1]: *** [snc.install] Error 2
gmake: *** [src.install] Error 2
devl06 [196]:
I saw a thread in tech-talk that appeared to address this but after applying the same fix to src/snc/Makefile by adding: HDEPENDS_METHOD=MKMF, I still get the error. snl.h is not being generated......
Any help would be most appreciated!
Sue Witherspoon
Staff Computer Scientist
Accelerator Controls Software
757-269-7579
Thomas Jefferson National Accelerator Facility
Sue Witherspoon
757-269-7579
