Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Problems building seq 2.2.4 on Linux
From: Ben Franksen <benjamin.franksen@helmholtz-berlin.de>
To: Mark Rivers <rivers@cars.uchicago.edu>, 'Sue Witherspoon' <withers@jlab.org>, Tech-talk <tech-talk@aps.anl.gov>
Date: Fri, 25 Aug 2017 09:28:44 +0200
I am a bit confused over this exchange. The problem seems to be that
snl.h is not generated? Is that why you use a patched version of lemon?
Am 25.08.2017 um 00:55 schrieb Mark Rivers:
> Hi Sue,
> My apologies, I found that my version of seq 2-2-4 also has a modified version of lemon.c.  Here is the difference
> Here is the patch:
> [epics@gse-marccd2 lemon]$ diff -U3 lemon.c.orig lemon.c
> --- lemon.c.orig        2016-11-25 11:50:21.000000000 -0600
> +++ lemon.c     2017-08-24 17:37:51.910633792 -0500
> @@ -403,6 +403,7 @@
>    char *tokendest;         /* Code to execute to destroy token data */
>    char *vardest;           /* Code for the default non-terminal destructor */
>    char *filename;          /* Name of the input file */
> +  char *outputdir;         /* Name of the output directory */
>    char *outname;           /* Name of the current output file */
>    char *tokenprefix;       /* A prefix added to token names in the .h file */
>    int nconflict;           /* Number of parsing conflicts */
> @@ -1576,6 +1577,7 @@
>    static int statistics = 0;
>    static int mhflag = 0;
>    static int nolinenosflag = 0;
> +  static char *outputdir = 0;
>    static int noResort = 0;
>    static struct s_options options[] = {
>      {OPT_FLAG, "b", (char*)&basisflag, "Print only the basis in report."},
> @@ -1594,6 +1596,7 @@
>      {OPT_FLAG, "s", (char*)&statistics,
>                                     "Print parser stats to standard output."},
>      {OPT_FLAG, "x", (char*)&version, "Print the version number."},
> +    {OPT_STR,  "o", (char*)&outputdir, "Directory for output files (default: same as input)."},
>      {OPT_FSTR, "T", (char*)handle_T_option, "Specify a template file."},
>      {OPT_FSTR, "W", 0, "Ignored.  (Placeholder for '-W' compiler options.)"},
>      {OPT_FLAG,0,0,0}
> @@ -1614,6 +1617,7 @@
>    memset(&lem, 0, sizeof(lem));
>    lem.errorcnt = 0;
> +  lem.outputdir = outputdir;
>    /* Initialize the machine */
>    Strsafe_init();
> @@ -1725,7 +1729,7 @@
>    /* return 0 on success, 1 on failure. */
> -  exitcode = ((lem.errorcnt > 0) || (lem.nconflict > 0)) ? 1 : 0;
> +  exitcode = (lem.errorcnt > 0);
>   exit(exitcode);
>    return (exitcode);
> @@ -2963,13 +2967,37 @@
>    char *name;
>    char *cp;
> +  char *inputname;
> +  int outputdirlen;
> +  char *outputdir;
> +  outputdir = lemp->outputdir;
> +  if (!outputdir) {
> +    outputdir = "";
> +  outputdirlen = lemonStrlen(outputdir);
> +  inputname = strrchr(lemp->filename,'/');
> +  if (outputdirlen > 0 && inputname) {
> +    inputname += 1;
> +  } else {
> +    inputname = lemp->filename;
> +  name = (char*)malloc( outputdirlen + 1 + lemonStrlen(inputname) + lemonStrlen(suffix) + 1);
> -  name = (char*)malloc( lemonStrlen(lemp->filename) + lemonStrlen(suffix) + 5 );
>    if( name==0 ){
>      fprintf(stderr,"Can't allocate space for a filename.\n");
>      exit(1);
> -  lemon_strcpy(name,lemp->filename);
> +  lemon_strcpy(name,"");
> +  if (outputdirlen > 0) {
> +    lemon_strcat(name,outputdir);
> +    if (outputdir[outputdirlen-1] != '/') {
> +      lemon_strcat(name,"/");
> +  lemon_strcat(name,inputname);
>    cp = strrchr(name,'.');
>    if( cp ) *cp = 0;
>    lemon_strcat(name,suffix);
> When I revert back to lemon.c.orig it fails with the same error you are getting.
> I appear to have made that fix on November 25, 2016.
> What is strange to me is that I cannot find any e-mail in which this change is discussed, either in my own e-mail or on tech-talk.
> Perhaps Ben remembers this fix?  In any event it looks like it a known problems page for 2.2.4 needs to be added here?
> http://www-csr.bessy.de/control/SoftDist/sequencer/Installation.html#download
> Mark
> -----Original Message-----
> From: Sue Witherspoon [mailto:withers@jlab.org]
> Sent: Thursday, August 24, 2017 3:52 PM
> To: Mark Rivers; Tech-talk
> Hi Mark,
>     Thanks for your response. The tech-talk thread I was talking about,
> which is related (I think) to my problem is :
> http://www.aps.anl.gov/epics/tech-talk/2017/msg00087.php  ..
> Ben mentions many-core build machines and also GNUmake versions.... I'm
> using 'GNU Make 3.81 built for i686-pc-linux-gnu'
> But you are right, I am not generating the snl.h  file.
> Do you know what rule triggers this generation?
> Sue
> On 08/24/2017 09:22 AM, Mark Rivers wrote:
>> Hi Sue,
>> I can't reproduce that problem.
>> My system:
>> seq 2.2.4
>> Redhat 6 (EPICS_HOST_ARCH=linux-x86-rhel6)
>> gcc 4.4.7-17
>> base 3.15.5
>> perl 5.10.1
>> I believe I have made only the following change to seq 2.2.4. Tthis was to fix a problem on Windows that was not related to the problem you are seeing.
>> corvette:seq-2-2-4/src/snc>diff -U3 snl.lt.orig snl.lt
>> --- snl.lt.orig 2017-01-13 08:38:51.976001963 -0600
>> +++ snl.lt      2017-01-13 08:35:39.777418847 -0600
>> @@ -829,11 +829,11 @@
>>       }else if( yyact <= YY_MAX_REDUCE ){
>>         yy_reduce(yypParser,yyact-YY_MIN_REDUCE);
>>       }else{
>> -      assert( yyact == YY_ERROR_ACTION );
>> -      yyminorunion.yy0 = yyminor;
>>   #ifdef YYERRORSYMBOL
>>         int yymx;
>>   #endif
>> +      assert( yyact == YY_ERROR_ACTION );
>> +      yyminorunion.yy0 = yyminor;
>>   #ifndef NDEBUG
>>         if( yyTraceFILE ){
>>           fprintf(yyTraceFILE,"%sSyntax Error!\n",yyTracePrompt);
>> When I build seq 2.2.4 with the -sj options it builds fine with only the following output
>> [epics@gse-marccd2 seq-2-2-4]$ make -sj clean
>> m[epics@gse-marccd2 seq-2-2-4]$ make -sj
>> 2 parsing conflicts.
>> Your first error is this:
>> ../snl.re:16:17: error: snl.h: No such file or directory
>> So for some reason it is not finding snl.h.
>> Mark
>> ________________________________
>> From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] on behalf of Sue Witherspoon [withers@jlab.org]
>> Sent: Tuesday, August 22, 2017 2:59 PM
>> To: Tech-talk
>> Subject: Problems building seq 2.2.4 on Linux
>> Hi,
>> I am having problems building seq 2.2.4 on linux:
>> Redhat 6 (linux-x86)
>> gcc version 4.4.7
>> Epics 3.15.5
>> perl v5.10.1
>> This is the complete output when building.
>> devl06 [195]: gmake rebuild
>> gmake -C ./configure clean
>> gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
>> rm -rf O.rhel-6-ia32 O.Common
>> gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
>> gmake -C ./src clean
>> gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
>> gmake -C ./pv clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
>> gmake -C ./common clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
>> gmake -C ./seq clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
>> gmake -C ./lemon clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
>> gmake -C ./snc clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
>> gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
>> gmake -C ./test clean
>> gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
>> gmake -C ./compiler clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
>> gmake -C ./validate clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
>> gmake -C ./unit clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
>> gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
>> gmake -C ./examples clean
>> gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
>> gmake -C ./cmdButtons clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
>> gmake -C ./demo clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
>> gmake -C ./johng clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
>> gmake -C ./simple clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
>> gmake -C ./small clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
>> gmake -C ./pvGetAsync clean
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
>> gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
>> gmake -C ./configure install
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../..
>> mkdir O.Common
>> gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../.. \
>>          T_A=rhel-6-ia32 install
>> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/convertRelease.pl checkRelease
>> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
>> gmake -C ./src install
>> gmake -C ./pv install
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../../..
>> mkdir O.Common
>> gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../../.. \
>> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF pv.d  ../pv.c
>> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../pv.c
>> /usr/bin/ar -rc    libpv.a        pv.o
>> /usr/bin/ranlib libpv.a
>> /usr/bin/g++ -o libpv.so.3.15.5 -shared -fPIC -Wl,-hlibpv.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32           -rdynamic -m32            pv.o    -lca -lCom -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
>> Installing shared library ../../../lib/rhel-6-ia32/libpv.so.3.15.5
>> ln -s libpv.so.3.15.5 ../../../lib/rhel-6-ia32/libpv.so
>> Installing library ../../../lib/rhel-6-ia32/libpv.a
>> gmake -C ./common install
>> mkdir O.Common
>> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
>> perl -CSD ../seq_release.pl 2.2.4 > ../O.Common/seq_release.h
>> Installing generated generic include file ../../../include/seq_release.h
>> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
>> gmake -C ./seq install
>> mkdir O.Common
>> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_queue.d  ../seq_queue.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_cmd.d  ../seq_cmd.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_qry.d  ../seq_qry.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_prog.d  ../seq_prog.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_mac.d  ../seq_mac.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_if.d  ../seq_if.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_ca.d  ../seq_ca.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_task.d  ../seq_task.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_main.d  ../seq_main.c
>> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_main.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_task.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_ca.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_if.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_mac.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_prog.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_qry.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_cmd.c
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_queue.c
>> /usr/bin/ar -rc    libseq.a        seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o
>> /usr/bin/ranlib libseq.a
>> /usr/bin/g++ -o libseq.so.3.15.5 -shared -fPIC -Wl,-hlibseq.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32           -rdynamic -m32            seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o    -lpv -lCom -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
>> Installing shared library ../../../lib/rhel-6-ia32/libseq.so.3.15.5
>> ln -s libseq.so.3.15.5 ../../../lib/rhel-6-ia32/libseq.so
>> Installing library ../../../lib/rhel-6-ia32/libseq.a
>> gmake -C ./lemon install
>> mkdir O.Common
>> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF lemon.d  ../lemon.c
>> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../lemon.c
>> /usr/bin/g++ -o lemon -Wl,-Bstatic -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32           -rdynamic -m32            lemon.o     -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
>> Installing created executable ../../../bin/rhel-6-ia32/lemon
>> gmake -C ./snc install
>> mkdir O.Common
>> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
>> re2c -s -b -o lexer.c ../snl.re
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m lexer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        lexer.o lexer.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m builtin.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        builtin.o ../builtin.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m sym_table.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        sym_table.o ../sym_table.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_tables.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_tables.o ../gen_tables.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_ss_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_ss_code.o ../gen_ss_code.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_code.o ../gen_code.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m analysis.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        analysis.o ../analysis.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m var_types.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        var_types.o ../var_types.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m node.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        node.o ../node.c
>> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        main.o ../main.c
>> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
>> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c lexer.c
>> ../snl.re: In function 'scan':
>> ../snl.re:330: error: 'TOK_SLASH' undeclared (first use in this function)
>> ../snl.re:330: error: (Each undeclared identifier is reported only once
>> ../snl.re:330: error: for each function it appears in.)
>> ../snl.re:331: error: 'TOK_MOD' undeclared (first use in this function)
>> ../snl.re:285: error: 'TOK_NAME' undeclared (first use in this function)
>> ../snl.re:287: error: 'TOK_INTCON' undeclared (first use in this function)
>> ../snl.re:323: error: 'TOK_PERIOD' undeclared (first use in this function)
>> ../snl.re:333: error: 'TOK_GT' undeclared (first use in this function)
>> ../snl.re:332: error: 'TOK_LT' undeclared (first use in this function)
>> ../snl.re:328: error: 'TOK_ADD' undeclared (first use in this function)
>> ../snl.re:327: error: 'TOK_SUB' undeclared (first use in this function)
>> ../snl.re:329: error: 'TOK_ASTERISK' undeclared (first use in this function)
>> ../snl.re:324: error: 'TOK_AMPERSAND' undeclared (first use in this function)
>> ../snl.re:334: error: 'TOK_CARET' undeclared (first use in this function)
>> ../snl.re:335: error: 'TOK_VBAR' undeclared (first use in this function)
>> ../snl.re:318: error: 'TOK_EQUAL' undeclared (first use in this function)
>> ../snl.re:325: error: 'TOK_NOT' undeclared (first use in this function)
>> ../snl.re:313: error: 'TOK_SEMICOLON' undeclared (first use in this function)
>> ../snl.re:314: error: 'TOK_LBRACE' undeclared (first use in this function)
>> ../snl.re:315: error: 'TOK_RBRACE' undeclared (first use in this function)
>> ../snl.re:316: error: 'TOK_COMMA' undeclared (first use in this function)
>> ../snl.re:317: error: 'TOK_COLON' undeclared (first use in this function)
>> ../snl.re:319: error: 'TOK_LPAREN' undeclared (first use in this function)
>> ../snl.re:320: error: 'TOK_RPAREN' undeclared (first use in this function)
>> ../snl.re:321: error: 'TOK_LBRACKET' undeclared (first use in this function)
>> ../snl.re:322: error: 'TOK_RBRACKET' undeclared (first use in this function)
>> ../snl.re:326: error: 'TOK_TILDE' undeclared (first use in this function)
>> ../snl.re:336: error: 'TOK_QUESTION' undeclared (first use in this function)
>> ../snl.re:312: error: 'TOK_NE' undeclared (first use in this function)
>> ../snl.re:311: error: 'TOK_EQ' undeclared (first use in this function)
>> ../snl.re:308: error: 'TOK_OROR' undeclared (first use in this function)
>> ../snl.re:301: error: 'TOK_OREQ' undeclared (first use in this function)
>> ../snl.re:300: error: 'TOK_XOREQ' undeclared (first use in this function)
>> ../snl.re:307: error: 'TOK_ANDAND' undeclared (first use in this function)
>> ../snl.re:299: error: 'TOK_ANDEQ' undeclared (first use in this function)
>> ../snl.re:296: error: 'TOK_MULEQ' undeclared (first use in this function)
>> ../snl.re:306: error: 'TOK_POINTER' undeclared (first use in this function)
>> ../snl.re:305: error: 'TOK_DECR' undeclared (first use in this function)
>> ../snl.re:295: error: 'TOK_SUBEQ' undeclared (first use in this function)
>> ../snl.re:304: error: 'TOK_INCR' undeclared (first use in this function)
>> ../snl.re:294: error: 'TOK_ADDEQ' undeclared (first use in this function)
>> ../snl.re:309: error: 'TOK_LE' undeclared (first use in this function)
>> ../snl.re:303: error: 'TOK_LSHIFT' undeclared (first use in this function)
>> ../snl.re:293: error: 'TOK_LSHEQ' undeclared (first use in this function)
>> ../snl.re:310: error: 'TOK_GE' undeclared (first use in this function)
>> ../snl.re:302: error: 'TOK_RSHIFT' undeclared (first use in this function)
>> ../snl.re:292: error: 'TOK_RSHEQ' undeclared (first use in this function)
>> ../snl.re:290: error: 'TOK_FPCON' undeclared (first use in this function)
>> ../snl.re:270: error: 'TOK_WHILE' undeclared (first use in this function)
>> ../snl.re:269: error: 'TOK_WHEN' undeclared (first use in this function)
>> ../snl.re:268: error: 'TOK_VOID' undeclared (first use in this function)
>> ../snl.re:267: error: 'TOK_UNSIGNED' undeclared (first use in this function)
>> ../snl.re:266: error: 'TOK_UNION' undeclared (first use in this function)
>> ../snl.re:277: error: 'TOK_UINT32T' undeclared (first use in this function)
>> ../snl.re:275: error: 'TOK_UINT16T' undeclared (first use in this function)
>> ../snl.re:273: error: 'TOK_UINT8T' undeclared (first use in this function)
>> ../snl.re:264: error: 'TOK_TO' undeclared (first use in this function)
>> ../snl.re:265: error: 'TOK_TYPENAME' undeclared (first use in this function)
>> ../snl.re:257: error: 'TOK_SS' undeclared (first use in this function)
>> ../snl.re:263: error: 'TOK_SYNC' undeclared (first use in this function)
>> ../snl.re:261: error: 'TOK_SYNCQ' undeclared (first use in this function)
>> ../snl.re:260: error: 'TOK_STRUCT' undeclared (first use in this function)
>> ../snl.re:259: error: 'TOK_STRING' undeclared (first use in this function)
>> ../snl.re:258: error: 'TOK_STATE' undeclared (first use in this function)
>> ../snl.re:256: error: 'TOK_SIZEOF' undeclared (first use in this function)
>> ../snl.re:255: error: 'TOK_SHORT' undeclared (first use in this function)
>> ../snl.re:254: error: 'TOK_RETURN' undeclared (first use in this function)
>> ../snl.re:253: error: 'TOK_PROGRAM' undeclared (first use in this function)
>> ../snl.re:252: error: 'TOK_OPTION' undeclared (first use in this function)
>> ../snl.re:251: error: 'TOK_MONITOR' undeclared (first use in this function)
>> ../snl.re:250: error: 'TOK_LONG' undeclared (first use in this function)
>> ../snl.re:248: error: 'TOK_IF' undeclared (first use in this function)
>> ../snl.re:249: error: 'TOK_INT' undeclared (first use in this function)
>> ../snl.re:272: error: 'TOK_INT8T' undeclared (first use in this function)
>> ../snl.re:276: error: 'TOK_INT32T' undeclared (first use in this function)
>> ../snl.re:274: error: 'TOK_INT16T' undeclared (first use in this function)
>> ../snl.re:246: error: 'TOK_FOR' undeclared (first use in this function)
>> ../snl.re:247: error: 'TOK_FOREIGN' undeclared (first use in this function)
>> ../snl.re:245: error: 'TOK_FLOAT' undeclared (first use in this function)
>> ../snl.re:244: error: 'TOK_EXIT' undeclared (first use in this function)
>> ../snl.re:243: error: 'TOK_EVFLAG' undeclared (first use in this function)
>> ../snl.re:242: error: 'TOK_ENUM' undeclared (first use in this function)
>> ../snl.re:241: error: 'TOK_ENTRY' undeclared (first use in this function)
>> ../snl.re:240: error: 'TOK_ELSE' undeclared (first use in this function)
>> ../snl.re:239: error: 'TOK_DOUBLE' undeclared (first use in this function)
>> ../snl.re:238: error: 'TOK_CONTINUE' undeclared (first use in this function)
>> ../snl.re:237: error: 'TOK_CONST' undeclared (first use in this function)
>> ../snl.re:236: error: 'TOK_CHAR' undeclared (first use in this function)
>> ../snl.re:235: error: 'TOK_BREAK' undeclared (first use in this function)
>> ../snl.re:234: error: 'TOK_ASSIGN' undeclared (first use in this function)
>> ../snl.re:298: error: 'TOK_MODEQ' undeclared (first use in this function)
>> ../snl.re:297: error: 'TOK_DIVEQ' undeclared (first use in this function)
>> ../snl.re:358: error: 'TOK_STRCON' undeclared (first use in this function)
>> ../snl.re:427: error: 'TOK_CCODE' undeclared (first use in this function)
>> gmake[3]: *** [lexer.o] Error 1
>> gmake[2]: *** [install.rhel-6-ia32] Error 2
>> gmake[1]: *** [snc.install] Error 2
>> gmake: *** [src.install] Error 2
>> devl06 [196]:
>> I saw a thread in tech-talk that appeared to address this but after applying the same fix to src/snc/Makefile  by adding: HDEPENDS_METHOD=MKMF, I still get the error.  snl.h is not being generated......
>> Any help would be most appreciated!
>> Sue Witherspoon
>> Staff Computer Scientist
>> Accelerator Controls Software
>> 757-269-7579
>> Thomas Jefferson National Accelerator Facility
> Sue Witherspoon
> 757-269-7579
Attachment: signature.asc
Description: OpenPGP digital signature
RE: Problems building seq 2.2.4 on Linux Mark Rivers
Problems building seq 2.2.4 on Linux Sue Witherspoon
Re: Problems building seq 2.2.4 on Linux Sue Witherspoon
Prev: RE: Problems building seq 2.2.4 on Linux Mark Rivers
Next: Re: SNC Sequencer 2.2 not working when reading remote IOC variables? Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: RE: Problems building seq 2.2.4 on Linux Mark Rivers
ANJ, 25 Aug 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
