Forgot the "environment file" in the attachment...
On 07/12/2017 04:54 PM, Florian Feldbauer wrote:
> Hey Ben,
> I setup the ca gateway using systemd. But I had only one gateway running
> on the machine.
> Maybe my scripts give you a good starting point!
> Best regards,
> Florian
> On 07/12/2017 03:06 PM, Benjamin Franksen wrote:
>> Hello
>> Does anyone have an example of how to start the CA PV gateway using
>> systemd? Is there a recommended best practice?
>> Note: we want to run many gateways on the same machine.
>> Cheers
>> Ben
| Dr. Florian Feldbauer |
| Ruhr-Universität Bochum |
| Experimentalphysik I AG |
| Universitätsstr 150 |
| D-44801 Bochum |
| Office: NB 2/134 |
| Phone: (+49)234 / 32-23563 |
## Debug level. Enter a value between 0-100. 50 gives lots of information, 1 gives a small amount.
#DEBUG=0
## Client IP addresses and port
## List of IP addresses that the Gateway client uses to find the real process variables
CIP=192.168.1.255
## Server IP address and port
## IP address where the Gateway server listens for process variable requests.
SIP=10.32.90.145
## Config files
## Files are searched in /etc/epics/cagateway
#PVLIST=example/GATEWAY.pvlist
#ACCESS=example/GATEWAY.access
#COMMAND=example/GATEWAY.command
#PUTLOG=putlog
#REPORT=report
## Timeouts in seconds
#CONNECT_TIMEOUT=1
#INACTIVE_TIMEOUT=7200
#DEAD_TIMEOUT=120
#DISCONNECT_TIMEOUT=7200
- CA gateway with systemd Benjamin Franksen
- Re: CA gateway with systemd Florian Feldbauer
Re: help - writing a table column from OPI BOY to PV Kasemir, Kay
<2017>
Re: CA gateway with systemd Wesley Moore
<2017>
